Matt D
S197 Pilot
I've been MIA too long, time to get back into things lol
MR Danner have you ever used Fuel the world's E85?
I did a quick test end of last year on the roller. I knew I would max out the stock injectors but I went for it anyway. First time I used any E85 (We don't have any at the pumps here)
Left the timing the same, Dropped the air fuel down to 11.8. Picked up 13Hp I let go around 6700 when the injectors had enough. I was pretty amazed to pick up that much that easy. The FTW has a bunch of additives compared to normal E85 from what I hear. Just wondering if you have ever used it? Or tested pump E85?
Going to give it another shot after slap some Id72's on it and buzz it to 8k
These cars putting up these huge dyno numbers, where's the timeslips? Or are these those same cars that are still running 11s? I can assure you my car wouldn't make anywhere near those kind of numbers. I'd probably be more than 75hp short of that unless I played games with the dyno to artificially inflate them.![]()
I am curious what kind of times you guys would have with a max effort N/A build and with guys who put a shit ton of thought and testing into your setups and optimizing your suspension setup.
Power by the hour built a Boss 302 with Kooks 1 7/8th long tubes the power by the hour intake a cobra jet intake manifold stage 3 cams and I forget if that was it or not but they made 501 HP through a JLT 110mm style intake and 65mm cobra jet throttle body so I am not sure how inflated the revolution automotive numbers can be if you believe the JLT is about a 10hp restriction and a non super cobra jet throttle body isn't going to flow enough cfms and that is where out of the gains from the cobra jet manifold comes from.
Most time slips I have seen are from just bolt ons with the cobra jet intake on them which didn't really apply here but a lot of guys are running low 11s if they take the time to setup the suspension and with minimal weight loss out of the car.
Are you planning on getting the cobra jet pulse ring ad well when you open up the engine?
FTW is the shit
We ran it with a complete stock engine in joe's coyote stock car.
Made over 500HP
the drivetrain is really light so we have less loss. Either way once you get it sorted out FTW is an easy 25 over pump or C10
Yes. Billet oil pump gears, Pulse ring, Boss Chain tensioners & Alum deep sump pan will all be added.
Yea I figured once I play with timing and buzz the motor up I could see some more gains. The price of FTW is an arm & a leg though
Oh btw I can you get me a quote together when you get a moment to have the special gear treatment done on a set of FRPP 4.88's? Like did to my 4.56's?![]()
Yes, read the part description... where does it go? lol and I still don't know what it does besides increases RPM?
http://newautoaa.blogspot.com/p/distributorless-ignition-system.html
Here you go, it kind of explains the purpose of it. If I recall correctly and am understanding correctly it goes on the back of the engine.
Wht sre your guys thoughts on Long Tubes size? I will be going with Kooks Long Tubes so I can keep the side pipes for my Boss, now it seems like the consensus is that the 1 3/4 are best for a N/A engine but is that still the case when you would be going with aftermarket cams and head work?
I'm not certain if the 1 3/4 or the 1 5/8ths would be better for this. I imagine the 1 3/4 would only be a slight bottleneck in the exhaust side but I couldn't say for certain. I would like to have my engine consist of Cobra Jet Intake manifold, SCJ TB, Stage 2 Heads and either Stage 3 cams or custom grind but I am not certain if a step up in Header size is worth it.
