So you feel that the STR.T's would be a nice match with the K springs?
First, shocks are dampers. They do NOT limit travel they control the speed of it. So when it's said that Bilstein's will kee you from "having a chance hitting the bumpstops" that's not true, at all. More to the point Bilstein's are quite pricey for non-adjustable dampers, and elsewhere in this forum is a guy who had them and now has Koni's and I think the statement he made about the Bilstein's and the H&R's he had was the "car bounced like a pogo stick"
For once I'll agree with SkyRender on his statement that coil-overs are not magic, they are in fact just springs and dampers, that happen to give you ride height adjustability. Some might seem like magic on the higher end of things because more time and effort (and therefore cost) are put into developing the springs and dampers together. But that doesn't mean any kit of great, or right for every person.
FWIW, the FRPP dampers have lots of good rebound. But they ride like complete crap, like sledgehammers. You can do SOOOOO much better, even if you don't want to go to an adjustable damper. Koni STR.T's are great for the guy who wants a composed car, no adjustment, and doesn't want to spend $500+.
I'd still put Koni Sports on it. Hard to bear the value, or the proven record of Koni's. And while not as cheap as non-adjustables you get a shock that has a lifetime warranty (well supported too when required) and doesn't loose it's starch in 40k miles, because you can add more rebound damping in. And that is actually how the Koni adjustment started way back as a tuning tool for the wear old shocks had. Since things have gotten MUCH better in terms of oils, seals, and generally durability, and that adjustment also allows you to play with the response and feel of the car and that's pretty what it's used for these days.
