dysan
Dis-Member
??? N/A car? Heck no....Built 11:1 stroker iron block, FRPP stage 2 heads, comp 127300 cams, Edelbrock E-force supercharger running E85. I have a feeling if I turned the boost up I would have no problems going into the 9's....
On the lowest possible boost pulley (3.875") which made 6-8psi the car ran 10.98 two weeks ago and one pulley down from that (3.5") which was 8-10.5psi of boost it went 10.64... I race in the Super Pro class at my local dragstrip and need it as consistent as possible..there is too much slack in the drivetrain with a locker which allows the car to rock a bit when staging it and sitting on the trans brake.
Also, the spool weighs a bunch less than the locker so that is an added bonus.
