DAMN IT, replaced the rear brake lines today and the damn left side still getting hot. The left side caliper moves when the brake pedal is push but I drive for 15-20 min and is super hot compared to the right side and start making noise and vibration.
I decided to go to the shop that did the rear end and welded the 9" ends and explained the situation, they told me to bring the car to check the brakes but I could be the 9" wheel bearing slipping off and getting the rotor hot. They told me they had to tack weld the locking ring in the wheel bearings before on other cars.
Funny stuff I found was left side wheel is tight on lateral (side movement) and vertical movement too. So I think the bearing of the left side should be good.
But the right side has a very very small play, side to side and up and down so it might have a Bearing bad there but that side is free as far a brake binding. Right side also makes noise like if the rotor was warp but doesn't get hot when I drive.
At these point I will let them check it but I think is bearing related, all the brake area is been covered from lines to rotors.
Anybody has had a bad 9" rear end bearing bad causing the brakes to bind or make noise and vibration in the brakes?
