This is the progression of my 09 GT:
After my first trip to the dragstrip, I discovered that my car wheel hopped terribly with the stock suspension. To fix it, I got drag radials (275/40 17 NT05R's) and Steeda chrome moly LCA's. This solved my wheelhop issue.
I then grew tired of the spongy feeling of the stock shocks and struts so I went with steeda sport springs and tokico d-specs. This really changed the feel of the car and gave me a connection to the tires that was completely absent with the stockers. This is still one of my favorite changes to my car.
My first dragstrip trip with the shocks/struts/springs was a disappointment as wheelspin was a big problem. It could have been the settings of the shocks/struts, the need for relocation brackets, or it could have been as simple as me forgetting to cut down my bumpstops, we'll never know. Other than that, the car still felt great on the road and living in BC, there are no shortage of spectacular mountain roads to play on.
I then fell into temptation of black friday sales and got BMR relocation brackets, BMR poly adjustable upper arm and mount, BMR radiator support with swaybar brackets, and a steeda Panhard bar and brace.
I installed all those parts at the same time and while I was back there, I noticed the bumpstops and all the black marks from hitting it-oops-cut them down at this time as well.
I used the top hole on the upper bracket and the middle hole for the lower brackets.
With these changes my 60' has dropped from 2.14 as my best stock time-wheel hopping the fillings out of my teeth down to a best of 1.70 and a dead hook. I am pretty sure with the WOT box and some more practice (only 6 runs so far with the latest changes) I think it will go deep into the 1.6's.
After I'm done at the strip, I set the shocks/struts to 3 1/2 turns out and it gives me a setup that far exceeds what the stock tires can hold. This will obviously be my next purchase.
This setup works for me for a street car that sees drag strip time. There are better options for the dragstrip and there are better options for carving corners but this is a good balance of both for me.
awesome autocorrect malfunctions brought to you by tapatalk
