Axle brace??? ,wtf...drag racers! BOYCOTT. WE WANT THE WATTS
That's the goal I assume BUT with the CHE brace you are adding a lot of weight for not a lot of strengthening. The CHE brace hangs under the axle which is not how I would orient a brace if my goal was to increase the rigidity of a live axle on hard launches. I would want it basically on the same level of the axle across the diff cover or around the front to actually strengthen the axle for launching.I am a little confused. What would be the axle brace for? To avoid the housing from bending like the CHE intent to?
Yep. Pretty much how I think... Corner carvers know how to drive and use that amazing newfangled thing called a steering wheel.i'd guess that most people that frequent this forum (corner carvers) would probably rather spend 6K on suspension components over a supercharger
Well, I agree somewhat.....but, it's hard to argue our other design we made up, compared to this one, in terms of strength.
That said - I don't think the strength will be an issue.
Trust me, the "track dogs" will be pleased with what we are, and will be bringing to the table. Fortunately, they will like the price point too - as we are taking our stream lined manufacturing process, and making it "work" for the community.
Clears wider tires, eliminates need for Sway Bar Relocation Brackets.
Also you may want to consider a smaller bar (option, or additional forward hole on existing bar) that would make the bar softer than a stock GT rear bar.
Do I sense a little Fred Puhn math, Kelly?
