crownaviation
http://www.tudyno.com/
Edit as the numbers were backwards lol My last setup MAINS were set at .0016-.0019. Looked pretty good and was surprised on those. Set the RODS to .0020 and those showed quite bit of wear but was expected as I was running "M" series Clevite bearings. Only a couple thousand miles on those bearings with new Kellogg crank. There was some wear on the edges of the front bearing but I likely got more life out of them than I should have. Was running Valvoline 10w30 racing oil with lots of zinc. My bearings were not made to last long tho. I am going with the same bearings and same clearance (Mains) this go also but will likely change up the ROD bearing clearances some. Color looked great tho.. no signs of any excessive heat or anything.
I rebuild every season anyway so there is that. I am going to switch to Joe Gibbs 5w30 and teardown at the same approximate mileage. I always beat it and will be running same power (1000hp) with the exception I will get there all on boost now instead of using the Nitrous as an additional power adder. Granted I only sprayed it that hard a couple times and pretty sure the wear accelerated from that and the higher rpm. I may be shifting at a little lower rpm now also so those all need to be accounted for. I suspect if I can still make the power at 6200-6500 vs 7k like before I will likely see less wear patterns like I did on this set of bearings.
Cams looked great. Had two followers (#3 and #6 exhaust side) starting to discolor tho and the bearings on those followers were loose (also new OEM at time of installation). Getting oil and oil pressure was never a concern. My VCT is locked out.
Will try to post a pic. Was not horrible but not as clean as the stock bearings look when those are removed (albeit they are a different material/purpose bearing)
