P0307
saleen07gt
St. Petersburg, Fl
I'm about a week away from putting on a set of ported cyl heads, frpp intake, gt500 tb and injectors and all of a sudden the car is intermittantly missfiring and setting a P0307 (misfire #7 cyl). No big deal, I've got new motocraft spark plugs, so I installed one new motocraft spark plug and coil in #7, cleared the code and the car seemed ok, until today. It is still setting a P0307, so I swapped #7 injector with #6, cleared the code, testdrove it and still intermittantly setting a P0307. WTF ?
saleen07gt
St. Petersburg, Fl
Wiring... or mechanical.
I don't think it's mechanical, it would be missfiring all the time. I drove it tonight, it was missfiring, ck engine light flashing for a few miles then all of a sudden smoothed out and ran great for the next 20 miles. Could it be a false code, maybe one of the other cyls are actually missfiring ? I'm going to change the rest of the spark plugs in the morning.
Sprayer84
Omaha, Nebraska
Swap the injector. Could also be throwing a code for the wrong cylinder. Need to do a power balance test with a scan tool
Kalatrax
Albuquerque, NM
That leaves it with a wiring issue. Probably a loose pigtail or worn off insulation on the injector or coil wires.
saleen07gt
St. Petersburg, Fl
Update : I'm losing the injector pulse for the first 5-10 mins during startup then the pulse comes back andwill run fine for hours after that. It acts like the injector driver in the PCM is failing.
Sprayer84
Omaha, Nebraska
That doesn't sound good. It's strange that it only is doing it on startup.
saleen07gt
St. Petersburg, Fl
It is strange, it litteraly won't pulse #7 injector for the first 6 mins during a cold startup, by the 7th min, the injector is working and the engine is running smoothly.
JeremyH
3V Fuel Guru
Virginia Beach
Make sure the injector plug is tight and the wires going in are good. When its not working on startup I would go wiggle the connector and push it tight and see if you get pulse.
saleen07gt
St. Petersburg, Fl
I did a wiggle test from the injector all the way to the PCM, nothing changed, I guess I could ohm out the wires from the PCM to the injector before I buy a PCM.
saleen07gt
St. Petersburg, Fl
Update : I suspected the PCM to be faulty (injector driver for #7 to be bad), priced out a new from Ford, almost $1,000 . Found a used one for $200, with the same part #and strategy code. It wouldn't start, had to program the PATS, that was $32.95, had access to a universal programmer. Uploaded my custom tune with the SCT and life is good again, car runs great, no more missfires. The place where I messed up was in programming the keys for the PATS, I was only able to get 1 key programmed, some how I made the wrong selection in programming tne 2nd key.
