Anyone have Ground Control camber plates? If so, how do you like them?
I think I'm going with these but not 100% sure yet. MM is my second choice.
I like Maximum Motorsports' plates.
Since these only mount one way, do they allow enough adjustment to add camber?
I'm looking to get approx 3 deg neg camber with a 1" drop (not take away camber to get back to 0 after a drop)
thanks for the replies guys
Roadracer350, Vorshlag plates are $500. That just seems way too much for what they are. I don't doubt they are nice though.
Vorshlag Ford '05-'14 S197 Mustang Aluminum Camber/Caster Plates & Perches
- Spring Perch '05-'10 OEM Style Perches
- Strut Style Koni - Long Stem ('05-'10) $494.00
Whiskey11, I think I'd actually prefer the poly donut both for noise and because it doesn't seem right to load a spherical bearing axially (pushing the ball thru the hole). They are usually designed to hold radial load. Are you using the GC street plates?
Steeda makes some nice plates and BBK is coming out with new cc plates also, both are on Steedas website.
Having said that though, if I had the money there is no question Vorshlag plates would be my choice.
Steeda Mustang Heavy Duty Upper Strut Mounts - 11-14
Market Price $388.83 Our Price $329.95
Their street plates are only camber adjustment but they are nice plates. 1.5* of camber adjustment and can be flipped to have 1.5* the other direction if for whatever reason you don't like more negative camber. Biggest "complaint" I've heard about them is that the street plates don't have an articulating spring perch on some form of spherical bearing but instead uses a poly donut to allow the perch to articulate when the suspension moves. I'm not sure the spherical bearing has much of a performance advantage that the average driver would see.
As for their "Race" plates, my understanding is that they require modification to the strut tower opening to install. They specifically told me that it was pretty substantial and that was the only way to get caster and camber adjustment on their plates. They wouldn't go into detail on that specific point but recommended against it. From what I've seen of their race plates, they are pretty pimpy parts that are well built and DO have a spherical bearing that the spring perch articulates on.
True they are expensive but they are worth it!![]()
There is a slight amount of caster adjustment about .3 The is no articulation in there street plates ....there is perch rotation around the poly donut . I guess you could get very little with some poly flex. The race plates have full (arch) articulation . I think your mixing the two types of articulation .
This...Vorshlag plates... No need to say anymore...
And this...True they are expensive but they are worth it!![]()
And this...Remember that old saying..."you get what you pay for?"
The Steeda plates are nice, but the MM plates off a little more camber adjustment (and caster). NVH is about the same from what I noticed between the Steedas and MM (maybe a tad less with MM).Steeda makes some nice plates and BBK is coming out with new cc plates also, both are on Steedas website.
