Sam, you looking to break 1000hp?
Is there anything you can do with a return that can't be done with a returnless?
Someone might correct me on this but all a return style really does is make it easier for the tuner. Set the regulator and that's it. The downfall is at lower power levels because that 5 bar needed to run wot is still there for normal driving. This means very short pulse widths are needed to run the motor at low loads.
Either system will work, but for big fuel demands, a return style is optimal. You will have a much more stable fuel pressure. Most tuners will recommend a return style system for anything over 650hp. Especially when the additional fuel demands of E85 fuel are in play. The Aeromotive A1000 or Eliminator are single drop in pumps for the S197 that will support big power. there are advantages to a single pump over muliply pump systems as well. I have the Eliminator pump and it rated at 875lph and support 1000hp+ on corn. Combined with the Aeromotive pump control and vapor lock is eliminated for a street application. The pump control is "pulse width" modulation just like the OEM fpdm.
A return system doesn't have a constant psi. For example, mine is 40 base and 60 at WOT under boost.I can understand how a return system is going to always have the same psi.
Same with a return system but it's as the boost increases the fuel pressure increases.As the airflow increases the psi increases.
Anyone have any reason not to run a "deadhead" system? It's a return style system, but is returnless at the motor. This is what I have planned for mine.
It goes; supply line to regulator. Return line from regulator. Then two supply lines from the regulator to the rails. No fuel returns from the rails which are capped at the ends.
I would haeve to dig thru all my old logs but I have been running a complete Fore Innovations return system with the 4i regulator, dual Walbro 465 pumps, -8AN feed and return. ID1000 injectors and always run e85 on that setup. 4ga wire to the pumps from the battery in the trunk but will soon change to the Fore innovations controller for simplicity
Fuel temps were rediculous before I installed a hobbs switch to control the second pump. It comes on at 3psi of boost so system is ramped up/ready when needed.
Ran just a hair over 23psi of boost at 55psi base pressure. Also using the frps signal..
I will need larger injectors for my build which sucks cause they were $2k alone. The ID1000 will not support 1,000rwhp on the corn
That's not correct. The supply line feeds the front of both rails. Out of the back of each rail to the regulator. From the regulator, fuel returns to the tank. Fuel is always circulating and not "deadheaded".
I was talking about the fuel injector pulse width. As the delta pressure goes up the injector has to be on for a shorter amount of time, at lower fuel demand levels in can be a liability.
I'm trying to learn, not argue. However, it's going to sound like I'm debating but I'm not.
I can understand how a return system is going to always have the same psi. It's regulated to blow off or return any fuel over the setting and not used.
What I don't understand is how a returnless has issues? I only have experience with my builds. With that said I've never had a problem with fuel pressure being stable. It's very easy to command different delta or base pressures for different air flows. I do quite a bit of data logging and am not seeing anything that would be dangerous. As the airflow increases the psi increases. The computer adjusts for the increased delta pressure and a/f doesn't suffer at all.
Is it possible that the s197 is refined to a point that it's more reliable than earlier returnless systems?
Neither will a -8 supply line. You may want to consider a -10 supply if your goal is 1000hp on corn. Also the return line should be the same size as the feed at a minimum for a return system. If the return is too small you get inaccurate pressure readings at the regulator.
This is my regulator:
That thing looks is going to start walking any moment, lol. Why all 90s? not a single line coming from a side or front at least?
Having the regulator before the rails will work. However, most manufacturers recommend the regulator after the rails. This reason is the regulator maintains the fuel pressure between the pump and regulator. With the rails in between the pump and regulator the pressure in the rails is very consistent.
I can say with certainty the 2 largest aftermarket fuel system manufacturers - Aeromotive and Magna recomend to install the regulator after the rails.
Not saying having the regulator before the rails won't work. It's just not preferred for most EFI installations. In the end its your car, install the system in the manner recommended by the manufacturer using the method you and your tuner are most comfortable with.
Lethal has been running their systems like this for a while without a problem.
IMO, reaction time. With a return system the ECU has to sense that you've floored it and then tell the pumps to speed up to increase pressure. While it happens fast, it still takes time. With a return style the volume is always there ready to be used.
