tim
Quick share of my experience the Motive Power bleeder: like many other users of this product for the 11+ mustang, i had to order the aluminum cap from Motive and like many others, still had problems with leaking fluid at the cap. After thinking i'd just wasted $80, I tried using the bleeder with just air pressure (12psi) and no brake fluid in the Motive - worked fine!
Using this air pressure only technique, there's no chance of brake fluid leaks at the cap. In between each corner, release the pressure, add fluid to the master cylinder, put the cap back on and go.
I've not tracked it yet after trying it this way, but for impromptu late night brake fluid changes, it worked really well.
One thing i really don't know, is whether there's a technical reason they don't recommend using the tool this way. ymmv
