Fuel's Winter Project: Build It Before It Blows
one eyed willy
Pizzle fo shizzle
Lakeland FL
We shall see Paul. I have my money on a ring or ringland also though
Did you have issues with the same pistons on your old setup Paul?
Top of fourth on a long pull, wasn't lean,no detonation....just a lot of heat....pop....enough smoke to let me know it was fucked.
Mahle, livernois 4032 Pistons.
JoshK
Modder AKA Fuel
Nebraska
#1-165.
#2-215
#3-200
#4-215
#5-175
#6-175
#7-10
#8-175
All done cold. Numbers are all over the place
lito
Caracas, Venezuela
Pour some of what you are drinking on 7 and those numbers will come up for sure, lol.
Sorry to hear this, let me know if I can be of any help.
05stroker
Never enough power guy!
Bullard Tx.
I want to cover my car in what I am drinking and let my wife light it on fire!
05stroker
Bullard Tx.
Well, the car is safe sense I am in Dallas this week.
Unless the wife takes things into her own hands...
JoshK
Modder AKA Fuel
Nebraska
Well I figured out why #7 has no compression but holds a leak down test. Can someone please explain the oil on the plug though?
JoshK
Modder AKA Fuel
Nebraska
a friend said that if it cant intake air seeing as how the intake valve cant open, then it sucks oil in from the bottom. Would this be a plausible explanation?
Dark_horse
KC MO
OH shit been there done that... how often do you abuse that 2step?? hit the rev limiter? that's what happened when I hit the factory rev limiter the last time I had to tear shit down...
JoshK
Modder AKA Fuel
Nebraska
2 step all the time. I wasn't the best with the rev limiter the last time at the track either. Did you need a complete rebuild Bobbie? With my compression test results looks like I am looking at needing a re-ring anyway.
JoshK
Modder AKA Fuel
Nebraska
I wish I had a bore scope to check that Manuel. Wont know for sure on the ptv for a few weeks sadly enough
Big thanks to Bruce for telling me to pull the cam cover before pulling the engine though. Even though I still think it needs to come out for rings.
Dark_horse
KC MO
Thankfully when mine broke every single little piece stayed in the head... I tore it down anyways.. I got lucky and everything was in great shape... no ptv evidence... You are going to have to do the same... pull that intake for now and look at the intake runners on the heads... I hope its not to bad Im leaning towards a rebuild.. expect the worse and anything better than that isn't hard to deal with lol
