Vorshlag 2011 Mustang 5.0 GT - track/autocross/street Project
Status
Not open for further replies.
claudermilk
SoCal
Another part that has been in and out of stock is our own camber plates. After a key piece was finally delivered from a machine shop supplier our Vorshlag S197 camber plates went off of backorder in July and we fulfilled every single open order. There were a lot. Word got out that we had this camber plate in stock again, and in just a couple of weeks y'all had bought us out of another machined part needed for these, ugh! The volumes we are seeing lately are simply unprecedented. For a market that is price sensitive (Mustang), and an offering that is admittedly one of the higher cost options, we sure have trouble keeping them in stock.
Well, when you make a great product that will happen. I got caught in that backorder holdup, but the wait was worth it. Excellent part. The only quibble I can think of is now I see whay MM has that 5th bolt & kidney bracket. It would be nice to have a stud on the upper plate to poke through one of the extra holes in the strut tower to lock that plate in place. Slightly longer bolts would be good, too as I had to change out my oil separator; your CC plate + strut bar + Moroso oil separator bracket does not work.
The battery replacement is interesting. It never hurts to shed a few pounds where you can. I'll keep this one in mind once the OEM needs replacing.
neema
Fresno, CA
Forgestar F14 18x10" on GT500 fronts = no workie.
Nope, the F14 18x10 does NOT fit over the 380mm Brembo. We tested it, above. Now the word from Forgestar is that the F14 18x11 and F14 18x12 does fit over the 15" fronts, but I haven't verified that yet. But the barrel on the CF5 18x10 does look dramatically different.
Ahh, I think you meant CF5 instead of F14 in your post below. Now it makes sense.
Vorshlag-Fair said:
We've been doing a lot of research and have found the 18x10" Forgestar F14 will clear the Performance Pack's 15" (380mm) Brembo front brakes, which is a relief. Anyone with the 15" GT500 front brakes can benefit from this as well.
Regarding the 18x11/12 F14s fitting 15"/380mm brakes, I wouldn't hold your breath unless they've changed their barrel design in the last few months. There's an 18x12 F14 used on a Porsche (et60) in my garage and the mockup sheet used to test fit Stoptech ST60 380mm calipers didn't fit. Granted, the wheel had an offset of et60. It may end up working with the lower offset needed for Mustang front fitment (the barrel expands toward the inside of the wheel), putting the caliper in a better spot within the wheel.
I'll throw some spacers on the 12" wheel I have to simulate 15-40mm offset and see if the Stoptechs will fit. One thing to note is that the Brembo 6 piston/15" brake is a slightly "taller" caliper and sits farther outboard than the Stoptechs I'd be testing. I need to get a mockup card for the Brembos and maybe that'll shed some light.
Thanks for sharing Terry.
edit: it's a bummer that the CF5s are a little heavier, but you can't beat the price.
Benjamin T
BC Canada
Update for August 26th, 2014:
Running out of machined parts has always been a struggle for a small niche suspension shop like us, as we have to depend on outside CNC shops to make many of our parts to our drawings and specs. But being an engineer and a racer myself, I'm very picky about our specs and who we allow to make our parts. After 10 years and about 15 different machine shops we still struggle with unpredictable lead times from outside vendors - and that's after weeding out more than dozen shops that couldn't meet our quality expectations, lead times, specified tolerances or shipping concerns. What used to take 2-4 weeks lately is taking 3-4 months, and that's with 100% domestic suppliers (we will NEVER have anything made overseas that has our name on it). A lot of this has to do with the economic downturn of 2008, when we lost a big chunk of the smaller CNC shops across the country. Now we're working on a brand new solution that we will implement to hopefully alleviate this problem, or tank my business completely, one or the other. No risk, no reward, right? I'm going to cover this big change for Vorshlag in detail soon, but until then please be patient while we push through these growing pains. If you have any doubts about any big ticket item you might want to purchase from us, feel free to call or email us to check inventory status or to place a phone order vs an online order. Thanks.
oh nooooo.... but your website says it's in stock when i placed my order earlier this week. am i too late? :yuck:
Vorshlag-Fair
Official Site Vendor
Dallas, TX
Project Update for October 10th, 2014: Yikes, got a little behind on this build thread, mostly due to the construction and build-out of our new shop space over the past month. Lots of Mustang service and fabrication work has been going on at our shop, even on our own 2011 Mustang - which is about to go to SEMA and compete in the Optima Ultimate Street Car shootout. Have news on the 2015 Mustang as well. First, let's cover two events we competed in and won in in the last month.
SCCA Solo at TMS Road Course, Sept 28, 2014
Once a year the Texas Region SCCA holds an autocross on the infield road course at Texas Motor Speedway. Most of their events are normally held on a parking lot outside the Speedway (aka: the Bus Lot), and they had one the weekend before right there. But this Sept 28th event was a higher speed, more flowing course that is always a lot of fun, essentially for autocrossers that have never done a track event before. They have requirements in place (3 prior events) to make sure that this is NEVER the first autocross someone enters, both to prove someone's driving experience as well as course working background.
Sure, they throw a LOT of cones onto the TMS 1.1 mile road course's turns, to keep speeds in check (top speed is probably under 80 mph), because as we've shown in our videos before this road course can be pretty quick (120+ mph) if you run it as it is laid out. This year's SCCA Road Course autocross was one of the best I've seen - I've run this event every year since about 2005. This time we got 5 runs, and I was entered in MAM class (Modern American Muscle). Our crew had mounted up the same set of 315/335 BFG Rivals we used way back in March at Goodguys, then at USCA, then at a few other autocross events in between. The rears were kind of chewed up so we mounted them inside-out, which doesn't seem to affect the Rivals one bit.
I spent Saturday at the Texas Defensive Shooting Academy, instead of doing construction at the new shop
I probably shouldn't have entered this event on that Sunday, as Amy was busy painting at the new shop and I felt guilty. To make matters worse I had spent the entire day Saturday out at a shooting range for a friend's bachelor party blasting hundreds of rounds through my Glock 34 as well as shooting FOUR different automatic rifles. I had so much fun that Saturday shooting with 12 college racing buddies, and everything turned into a competition: shooting steels on two lanes side by side, comparing groupings, shooting AR15s at tannerite explosives, and then the king of them all: the driving shooting course! The video below was my best "drive-by" round, where I blew through 6 magazines and hit a lot of steel targets.
Driving + Shooting = Crazy but Fun!
I'm not a "gun nut", but this is Texas and its like an unspoken law that everyone here has to show mastery with their firearms. What's the saying? "Never tell a man he can't shoot, drive or f*ck." ;) We all know I can't drive, and my shooting is marginal, but I'll skip that third one. This outing made for a really fun day, but I was wiped out from the sun (and too many drinks at dinner, and a stressful Texas A&M football game that they won in OT!) and then racing on Sunday, whew. Busy weekend during the middle of a shop construction thrash.
Anyway, so I was running this SCCA event without my normal sidekick Amy, for once, and that meant loading/unloading the trailer amd working my assignment as announcer alone (Amy usually runs the computer), and I figured it would be boring. Wrong - there were 146 entrants at this event, 8 in MAM class, and the CAM class entrants were talking smack and challenged me to a bet (loser buys lunch): fastest MAM vs CAM class time!
Left: Mike and I parked our trailers side by side in the paddock. Right: Mike running his 67 Camaro at Goodguys the next week
Both of these classes (CAM and MAM) are very similar, and some SCCA regions merge them into one class (CAM). For once were running in the same heat, on the same style tires, so our times might actually correlate. Mike Dusold runs his twin turbo LS powered 67 Camaro in Goodguys events in the Pro class, and is once again going to Scottsdale for the annual Goodguys invitational shootout. We don't often meet up at the same autocrosses on the same street tires, so this would be fun. :)
My first run was pretty tame, as the layout had changed from previous years' courses (offsets and slaloms everywhere, but in new places). I liked the flow, but they managed to cone off all of my "green shortcuts" from the past, so there was no secret advantage to knowing this 1.1 mile road course layout, heh. I put in a timid first run that was clean and noted a half dozen places where I could go faster. One major slow-down was my 2-3 upshift, which didn't go at all smoothly, and I coasted for about a two count before I finally got it in gear. That cost me a LOT of time... and reoccurred on runs 2 and 3.
I was worried that I had messed something up, but after talking to several other S197 Mustang drivers in MAM, we were all having this issue. Turns out that the course layout was arranged just perfectly to load up the drivetrain in a high g lateral maneuver that is was not allowing the damned remote shifter to line up properly for the upshift. I've even got poly motor mounts and the trans bushing inserts, too. Literally everyone was missing the 2-3 here. One of our MAM class competitors and customer's partially exploded his pressure plate (locking the car with the clutch engaged all the time) trying to make that shift, and had to have it towed home (luckily it was still under warranty).
Slowing and pointing to a downed cone on an aborted run 4
So on runs 4 and 5 I short-shifted 3rd gear very early, but with the torque this Coyote 5.0 makes it didn't slow it down a bit, and in fact I dropped a lot of time by not coasting and cursing at the shifter. After installing one of these Blowfish Racing shifter "cages" in a customer's Boss302 earlier this week, I'm thinking this might be a good idea for ALL 2011-14 Mustangs with the Getrag MT-82 6-speed.
Left: We've done a lot of custom work on this green Boss302. Right: Installing the Blowfish Racing shifter cage was fairly easy.
Event photo and video gallery: http://vorshlag.smugmug.com/Racing-Events/TX-Region-SCCA-Road-Course/ (most of these pictures were taken by Brad Maxcy)
My 4th run was my fastest, but we noted that there was a mystery cone that got called in but never announced. And after checking the printed times it turns out I had a cone on runs 2-5 and never knew it! The announcer wasn't calling out all of the cones, and the times were posted about a 1/2 mile away from the grid/paddock area, and without Amy there to help check times I was clueless.
In-car video from my 4th run, with the "mystery cone!"
The weather was beautiful all day and since we ran in heat 1, worked heat 3, that meant I could leave early (skipped watching heat 4) and get home to try to SLEEP (haven't done much of this lately). In the end my 4th run would have beat CAM, which would have put me in 4th for overall PAX placing, but that cone tho. GRRR!
I had to sit on my first freagin run, the recon lap where I coasted for seconds trying to get the car to upshift. That run ended up still winning MAM class by a second, but I lost to CAM, so I owe Mike lunch. Oh well, can't win em all! Kudos to Mike and his crew at Dusold Designs. :)
There's the Final class results above, and the PAX results below. Again, hitting that cone cost me 12 spots in the overall PAX results. Gotta do it clean!
Goodguys at TMS, Oct 5, 2014
This was the event I was really prepping for when we mounted up the street tires, the weekend before. Of course any practice on street tires will only help our chances at the Optima shootout after SEMA, which is our "Big Event" of 2014, but there are always great PRIZES on the line at Goodguys for winning the All American Sunday (AAS) class. I've done 2 of these events in the past, and won the Spring event here in Texas. I really should have been spending the day painting at the new shop, but instead I entered and ran the Goodguys Sunday autocross - I wanted that cheddar!
Event photo and video gallery: http://vorshlag.smugmug.com/Racing-Events/Goodguys-TMS-100514/
These Goodguys autocross events are particularly tight and often require the use of 1st gear. The last 2 events in Texas used the same course, which was about 70 seconds long and you had to drive one particularly nasty section twice per run. This time they chopped off the extra lap, changed a few things up, and made a much more enjoyable, and quicker to run, 40 second autocross course. Yes, it was still tight, yes it still had a pirouette cone, but it wasn't so long that it made the runs drag on forever. The shorter course made for quicker running and instead of 3 or 4 laps like in the Spring, we got 6 or 7 runs (with a larger entry list) and were done sooner (they stopped adding times to the results sheet at 11:30 am).
Normally these guys start at about 9-9:30 am, so we got to the host hotel to check in (can't check in on site) at 7:45, unloaded the trailer at 8:15 am, and rolled up about 8:30... and they were about to start! Crap, no chance to walk the course, but it looked the same. As soon as I saw a car go through I realized it was a different layout and I'd have to learn it on the go. Finally got the car teched (missed my 1st run) and got in line to go. 30 feet into my first run I went the wrong way around a lane change and DNF'd. I figured it out as soon as I did it and rejoined the course for a look at speed.
Next time up I had watched a dozen runs and knew the proper route and knocked down a high 39 second run, plus one cone, which was about 3 seconds quicker than anyone else (cone only counts as one second). Blanton Payne was there in his LS1 swapped Genesis Coupe and he was the fast time to beat after first runs - he's a local autocrosser and has won the AAS event before in this car. He also runs the Friday-Saturday events in the FUN class in his vintage Mini cooper, and is always pretty quick in that tiny Mini.
By run 3 my lines were getting better and I had abandoned going down to 1st gear in a couple of sections. This was the first time I had done a Goodguys event here without using 1st gear, and I wasn't sure how it would work. Well once again the prodigious torque of the Coyote 5.0L proved up to the task and I dropped significant time and fell into the high 38s.
Run 5 was my quickest with a 38.5 second run
Runs 4 through 6 were more of the same - clean runs with 38 second times. My 5th run proved to be my best with a 38.5 second lap. The next closest time in AAS was a high 40, so I won this event by 2 seconds, just like back in the Spring. Of course the provisional results posted on Pro-Touring.com's forum are missing my times as well as about a half dozen others, but it seems like a glitch that will get fixed before the official results are put on the Goodguys website.
No matter - we got that stack of gift certificates and another free set of BFGoodrich tires for winning AAS, got to drive across the stage for the awards ceremony, and the whole nine yards. Josh Leisinger won the PRO class (Friday-Saturday pre-74 domestics) in a beautiful and nasty 800 hp 64 Corvette (see above). Robbie Unser (yes, of the Unser racing family) won the Street Machine (SM) class in his 64 Chevy II built by Speedway, and upon that win was bumped up to PRO class with Goodguys from now on. Both of those guys ran 2 days prior and were quicker than my runs, and 5 other Pro or SM cars beat my best time. That's frustrating, but with less than half the number of runs, and a car thats likely 600 pounds heavier than all of theirs (min weight in PRO and SM is 3000 pounds), I guess I should expect that.
For the 2015 season were building a lighter car that won't have to have these "its heavy" excuses any more. Honestly, the 3600 pound EVO X in the 2009 season and the 3600 pound Mustang from 2010-14 seasons were, by far, the heaviest cars I've ever raced. They were both great in many ways, and we developed a lot of good parts for both chassis, but I really miss racing in the car below...
Yes, I've showed this picture before. I really REALLY miss racing in a car like this!
After it was caged and had 2 seats, this BMW LS1 car tipped the scales at a whopping 2550 pounds. It made 490 whp with a mild LS2 based 7.0L, on 93 octane fuel. It had all of the factory metal and glass, save the door glass. THAT combination is what I miss, and I miss it dearly. I am building another for 2015 - a BMW E46 coupe with big LS V8 power, big aero, and big tires.
We learned a ton of tricks on this Mustang, but its time to try something else, and I have our red Mustang tentatively sold after SEMA. We will still get a LOT of S197 Mustangs in our shop every week and we will continue to develop products for these cars. Same goes for the S550 Mustang - its even heavier (3800 for the V8). Beautiful car, the new IRS should really help the ride/handling, and Ford is gonna sell a ton of these cars. Just not to me, at least not this year.
continued below
Vorshlag-Fair
Dallas, TX
continued from above
Vorshlag Not Buying 2015 Mustang
Yes, I know I have one on order (actually 2), and I'm disappointed that they aren't here yet. If we could have gotten the 2015 GT at least 8 weeks before SEMA we would have bought it, made some mods, and taken it to compete in the Optima event. But these cars, as everyone knows, were delayed. And they are a good bit heavier than promised.
Not gonna happen for 2014
For business reasons it just doesn't make sense for us to buy a 2015 Mustang right now - especially one that we aren't going to race. Spending $45K+ on a brand new car to then cut it up and ruin its value is nuts, but racing a 3800 pound car is equally as nuts, for us. We need an attention grabbing car to be campaigning, and the numbers just don't work for this new S550, for us. When the S550 "Body In White" is released, then we'll see. I also have a friend in the insurance business looking for a cheap 2015 Mustang for us - one with a front hit (I like the GT350 front bodywork better), a flood car or a "hard theft" recovery. This way we can MAKE IT LIGHTER without ruining the value of a $45,000 car.
Yes, it sucks that we won't own one - but we will still develop parts for these!
Honestly, we just cannot afford to purchase and own every car we want to develop parts for, so we'll be using customers' and testers' cars to develop the suspension parts, brake cooling, wheel sizes, camber plates and other parts Vorshlag is known for. We do this on lots of chassis. Stay tuned to see what we do with the 2015 Mustangs when they arrive at our shop. They are just NOW starting to arrive around the country... but our orders aren't scheduled to be built for weeks yet. It would have arrived sometime in November, well past SEMA. Funk that.
Other Recent S197 Work at Vorshlag
We're making good headway on Jamie Beck's 2013 Mustang GT, turning it from a street car into a dedicated (and class legal) road race car. The cage was wrapped up about 2 weeks ago and then I took it to Sherman, Texas to have our friends at Heritage work their paint magic.
After picking it up at Heritage and unloading it outside in the bright Texas sun it was blindingly bright. They did an excellent job and used a GALLON of paint on the inside, and spent 4 days prepping and spraying the interior, cage and trunk lid. The trunk lid and wing end plates were shot in 2 stage, water based, OEM matching white and the interior was super hard single stage paint.
Ryan has spent several days reassembling the car then getting the wiring harness de-pinned, wrapped, routed, and adding the mil-spec connectors at the front and rear bulkheads.
The defroster/heater core went back in and then the dash itself was mounted to the brackets that were welded to the dash bar. The center stack panel was from Watson Racing and Ryan is wiring in systems to use the toggle switches Jemie provided as well.
We have the main fire bottle mounted with dual pulls, one at the cowl (corner worker) and another at the center stack (driver). There is an additional Halatron 2.5 pound hand held fire bottle also being mounted in the cabin, to put out brush fires or other small flame ups that don't warrant blowing the on-board full fire system.
Ryan has worked on pro race teams in World Challenge and Daytona Prototypes, and his expertise there shows. Jamie comes from the battery industry, too, and once he spoke with Ryan they went a little further than normal on the electrical rework. Instead of re-using the fuseable links the factory uses at the power block fromt he stock battery location, we now have high amp/resettable circuit breakers in the engine bay, and a trick solid-state main power disconnect (kill switch) with dual kill switches - at the cowl and center stack.
New Steel Front Flares for our 2011 Mustang
Its no secret that I've never really loved the plastic flares we made for the front of our Mustang in 2013. We rushed the front flare job before the 2013 NASA Nationals, and after we had Heritage make steel rear flares the fronts in the Spring the front looked even worse...
Then I crashed the car at Road Atlanta and destroyed the plastic flares, so we "patched" them with plastic race roll and they look even worse. The difference front to back is alarming.
With our placement in the SEMA show in Ford's 50th Anniversary of the Mustang booth area, we had to step up our game. I asked our fab guys what they needed to make these flares in steel, and to look better, and they told me to buy these tools: an English wheel and a shrinker/stretcher. We already had the bead roller and welders needed.
So those tools arrived this week and Ryan got to town. The old plastic bits were unbolted and then he made the vertical arch piece, shown above at right. The main flare sections are made in 2 pieces, to match the factory fender - just bigger. The lower crescent moon shape vertical piece is nearly identical to the factory fender, with a rolled lower lip for strength and to give it a smooth edge. The upper flare section is all rolled out on the English wheel to get the curve right.
Lots of cutting, fitting and rolling later, the flare looked like the above shots. Then the old fender was cleared of paint at the flare joint and he spent time merging the 2 flare pieces (and somehow adding a radius to that joint?) and then joining them to the car. He is remaking the front portion as well, after he finished the main flares that weld to the fenders on both sides. The front portion will mount the the bumper cover, and might look a bit different. This has all got to be painted as well, so its a time crunch.
They look amazing, and I'm only sad I didn't get to see these coming together. Shop Manager Brad and I have been working night and day for the last two weeks at the new shop, getting the build-out done. We're really close, and have to be moved in by Oct 31st. We need to have Jamie's car and our Mustang done by Oct 25th, where we'll be running them at the Five Star Ford ECR track day. Then we start the move on the next day, the 26th, and have to be moved and operational in about 2 days. Then loaded up and headed to Vegas for SEMA by Nov 1st. So its going to be frantic!
Look for my next update... maybe right before we head to Vegas? Or maybe after SEMA/Optima are done. Its going to be tight!
What's Next?
Oct 25, 2014: Five Star Ford track day at ECR. We will be there hopefully with the finished fenders and paint on our Mustang with Amy giving some ride-alongs. This might be our last ECR event in this car ever... Come join us. You can sign up and pay here: link. More info on the Facebook Event Page. We will have our crew there for trackside maintenance, and they just repaved a huge swath of the track (Turn 5 to Turn 6), which should smooth out the worst of the bumps.
Oct 26, 2014: Vorshlag moves to its new location at 1703 Capital Ave, Plano, TX 75074. Our number should stay the same. It might be frantic for a few days, so we might have limited phone coverage for a few days that week.
Nov 4-7, 2014: SEMA Show! Look for our car in the 50th Anniversary of the Mustang Exhibit. We will be down to about 2 folks at the shop that week, as most of our guys are going to the SEMA show and OUSCI event (a different group of us is going to the PRI show in December).
Nov 8-9, 2014: 2014 Optima Ultimate Street Car Invitational! Here is a breakdown with pictures and details about all of the USCA Drivers Invited to the 2014 OUSCI - link. Last time I looked we had 8:1 odds to win it all? I'm hoping to just finish in the top 10.
Until next time!
ArizonaGT
Road Course Member
Phoenix, AZ
The GMW route is very potent, especially since you already have one built, ready to go!
A couple buddies of mine out here in AZ are preparing E46 widebody versions like the old PTG cars, with Schwanke LSXs and all the goodies. They should be ridiculously fast.
Plus as far as the '15s are concerned, the market will be flooded with them in a couple years so there is no harm in waiting--as long as you can do your development work on customer cars.
Looks like the new shop is gonna be killer.
Beach Park, IL
Will Vorshlag be carrying these? Not many parts impress me but that seems like a well thought out design that solves a _lot_ of problems.
< Guy who trashed 3rd and 4th gear synchros with his giant ham fist and whose wife hates the whiteline transmount insert.
zquez
Death Dealer
the sky
I'm sad they don't make one for the 6060...
We can only hope! Maybe if we bug the guy enough he'll make one. lol
Ugh I daydream about doing this to my car ALL THE TIME. Not to mention completely redoing the harness and using mil-spec connectors. Coming from aviation, automobile wiring is atrocious.
modernbeat
Jason McDaniel @ Vorshlag
Official Vendor
Dallas, TX
Most people do not realize that most OEM automotive connectors are built to withstand 4-6 plug/unplug cycles when they are new, and less after aged and heat cycled. But the cost of motorsports or military quality terminals is ten to one hundred times the cost. I've got a lot of wiring tools to make proper harnesses and I believe that even only buying good deals and used tools I still have over $1500 just in my wiring tools. The crimp dies for solid pin Amphenol connectors were particularly expensive. Special strippers for Tefzel wiring, solder pots, pin extractors, heat shrink printers and all the other parts don't look all that expensive by themselves, but as a group, add up to a chunk of change.
There's a place for motorsports wiring, and a place where you keep the stock wiring maintained, or just augment it as needed.
Vorshlag-Fair
Dallas, TX
why do you need one for the 6060?
I think he's referring to the remote-shifter mounted TR-6060 that comes in something like the GT500 or 5th gen Camaro?
We've changed out a lot of MT-82s (remote shifted) to Tremec T56 Magnum XLs, which are direct mounted to the tailshaft. Huge difference in feel, strength (700 ft-lbs rated), gearing, and all that. Our Tremec supplier is staying busy making T56 Magnum XLs for racers in Mustangs and 5th Gen Camaros both...
We had him make a "GM" style Magnum XL for our Scion FR-S LS1 swap, which has the shifter hole WAAAAY back from the firewall. Worked like a charm.
Status
