BMR Watts Link - Teaser
The BAB was replaced with this, on the passenger side:
The axle mounts....zOMG:
That axle mount is the real deal, Loads of surface area. It will not slip. That's got U bolts /saddles, solid saddles, double saddles etc, beat hands down.
ModdedMach
Detailer of shiny things.
Yea it looks solid. If u really wanted to, once u got it setup and cranked down, you could just put a couple tack welds on either edge to insure it doesn't shift under pressure.
popeye
My initial thoughts at seeing the Cad drawings of the axle mounts was, wow that will be heavy, but mounted up it seems to be well sized and suited to the task. Looks great
Barricade
Decepticon Extraordinaire
The Alamo
...Thoughts?
Does it come in Black and white?
On a serious note I bet it wouldnt fit with a Saleen rear diffuser....??
The furthest it goes back is the standard panhard bar location, correct?
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
Does your saleen rear diffuser prevent the use of the stock sway bar? Because the sway bar is behind the watts linkage.
ModdedMach
Some rough drafts.....I likey.
Thoughts?
I likey too. Looks hefty but not too bulky. Axle clamps look like they can get a good purchase on the axle too. And I bet the unsprung weight addition is very minimal
mavisky
Atlanta, GA
hmmm, any word on whether or not this would be compatible with the convertible bracing now that we're further along in development?
claudermilk
SoCal
Definitely a different take on it. For me, I'm thinking I'd go with the diff-mounted version.
I'm trying to visualize how the sway bar would fit in there. It looks like things will be getting tight.
ModdedMach
Once the roll center is adjusted properly, some people don't even run a rear sway.
I'm sure BMR will leave room though. I'm sure a lot of people will want to run at least the stock sway bar, including myself
Barricade
The Alamo
I got up under the car....and Im thinking there will be room for it.
Now if I can just get it in black & white. lol
ModdedMach
Vht enamel + duplicolor adhesion promotor. Lolbany color you want
I'm sure BMR would be willing to send you a bare metal unit to paint.
Sky Render
NW of Baltimore, MD
BMR has sent people bare metal products before. Also, black is one of the colors they offer.
But why does the color matter?!
ModdedMach
I think he meant black and white in print to make sure it fits.
<facepalm>
I thought he was referencing this car. Im pretty sure that was the reference. Why would you say black and white then post a squad Saleen car lol
