How you destroy a brand new ARP Coyote balancer bolt.
Rings arrived today so everything looks good for install on the 2nd.
Enviado desde mi MotoX
So it takes a lathe? What were you doing, cutting it down and rethreading?
Yeap.
Probably some mech or material engineer is swearing at me from somewhere but I can't find a proper bolt here and the ones I've found I just don't trust they are really at least 10.9 so I chose to do this.
I'd think the bolt would be too hard to machine without annealing and reheat treating. Is that what you found out? I'd also think that a 10.9 would work just fine with the correct torque. As you know the keyway and friction are doing all the holding. The bolt is just there for a failsafe "just in case". You could always drill the head and lockwire it to feel better, lol.
Why didn't you just order the raw material, machine it, then send it off to be heat treated?
Good expiriment to see how cut threads work vs. Rolled. As long as they don't strip on install it will probably last.
Done yet?
Nooooooooooo! Hope to get it done tomorrow and get it into the car Sunday. If all goes well, obviously.
Sent from my Nexus 7 using Tapatalk
I hope to me dropping mine in next Sunday also, good luck. Cant wait to see how this turns out.
The same to you, hope the planets align well for 3V engines on Sunday.
I will try to do a video of the first start, but an actual first start video, not after everything has been worked out already, as you commented the other day.
Good, I like to see all the smoke and everyone running around to see where it is coming from in a big panic! LOL
It has never happened before but never took video so chances are high this time, lol.
GoPro's cause accidents.![]()
no, they just make accidents entertaining for the rest of us lol
Had a close look at mine and it turns out that the Roush UDP is made by PowerBond, it even has the powerbond logo on it. It is Australian made so it is not some cheap Asian manufactured piece.Is a Roush UDP (looks really nice BTW, way better than Steedas, if you one makes the typical and some times idiotic "looks" valuation) and plan is to use some sealant at the key as with the others. I think the snuggy fit is more because of the reworked nose.
