We get it that some of you guys don't have the desire for an MCS or AST adjustable monotube coilover. They can and do work well on the street, especially if you choose the spring rates right, but the price point is out of reach for many (we're shipping 3 sets of MCS S197s this week along - so some folks do make it happen).
And while our Bilstein StreetPRO set-up is a lot of suspension for the money ($1499) - with inverted Bilstein monotubes, your choice of FRPP springs, Vorshlag camber plates and new rear shock bushings - it still lacks one key thing that many of you want... adjustable ride height.
We already make a rear ride height adjuster set-up for the back of the S197, shown above. So setting the rear spring height is easy, and going this route allows you to use more common coilover springs (for lots of choices in length and spring rate). But what about the front?
Honestly, if bilstein made a height adjustable coilover with no rebound adjustment it would suit most people's needs. Most people that think they need an adjustable shock, really don't. Especially when you consider that it only costs $60 to revalve a bilstein. Versus $150 for Koni, AST etc.
Your wish may come true sooner than you think...
We're testing this inverted Bilstein monotube coilover on a customer's Mustang this week. It will utilize a 2.5" ID coilover spring and have over 2 inches of ride height adjustment range.
Since the inverted strut insert easily unbolts and removes from the outer strut housing, we can cut/weld/modify the housing to accept the threaded collar without damaging the internal hydraulics. We CNC machine the threaded collar and lower perch shown above to fit another Bilstein housing already (for another chassis - but the OD is the same) and will be making a complete S197 coilover set-up using Bilstein inverted dampers very, very soon.
Stay tuned...
