I don't recall needing to swap my pinion flange when I went from the stock 2 pc shaft to the Axle Exchange 1 pc.
Maybe I had the adapter setup, I don't recall. The one you have now looks like the one I am using currently with my custom DS.Put my driveshaft in April 2010, then they provided a new pinion flange. I believe they used a 1350 series flange yoke. My car is an auto not sure if that made a difference. Now I understand they have an adapter that bolts directly to the current pinion flange. This is a current pic of the flange installed in 2010.
The original pinion flange for the OEM 2 piece looks like this.
Like a pro! Looking forward to seeing the tooth pattern.
Using a tooth contact pattern chart, what's your opinion on yours Scott?
You said you narrowed the rear 1". Will you still be using 15x10 race stars with stock backspace? I was thinking of going 1" but then I thought obout doing 2" so I could use a 6" back space. Have you test fitted to see if the 10" wide wheel would rub. Ideally I would like to narrow mine so I can lower the rear and not rub. Other wise I might just stick with a 275 on a 8" wheel. So many dang choice I can never make up my mind lol.
