dysan
Dis-Member
Williamstown, N.J.
Made my new custom alternator mount to put it where the a/c used to be. Got tired of having it reverse mounted how the Edelbrock blower kit does it. Now it will be much easier to change my belt and blower pulley.
3/8" aluminum plate, cut it with my jig saw.
Have it baking in my oven now with gloss black powdercoat.
dugstang
Atl
Finished taking the blower kit off, packaged it up and will ship out monday to its new owner. Also test drove a couple focus st's
Johnf78
Upstate NY
Finished installing Bmr lca relocation brackets, Lca, adjustable panhard, adjustable Uca, Uca bracket and the biggest pita ass poly differential bushing.
Wicked GT
OCD with ADD...
Omaha, NE
Finally installed my Steeda front sway bar... took it out for a quick banzai run before the snow hits. Love it!
Doug M
Fast Cars & Freedom
AL. Baby
Man, I so need you to live closer! I got most of the same parts together. Except I need some struts. That's the only thing I got to save for.
chandlern
Royal Palm Beach, FL
Wife has the flu so I've been hiding in the shop staying busy; full detail, changed the plugs, cleaned the air filter, swapped the coolant tank, and installed the new head unit I got for christmas and the old shaker 1000 box/amps. Just have to change fuel filter, pull the longtubes and wrap them, and figure out a new grill for the gtcs lower...
BeachMonkey100
Myrtle Beach, SC
Got the transmission back in and all is good! Got the halos in as well, new upper and lower grill installed too. The hardware that was sent was junk I didn't even use it, stainless bolts and locking nuts for the win. Plasti dipped where the grills are to change it up, think it came out great. ImageUploadedByTapatalk1420346020.245579.jpg
Unreal
Gilbert, AZ
Installed my viking DA rear shocks. Didn't come with dust covers, didn't mention them so I just put them in. I assume that is ok? Any reason I should pull it back apart to put dust covers on?
dysan
Dis-Member
Williamstown, N.J.
Started installing and fitting the new carpet (no heavy vinyl backing and weighs sooo much less than the stock carpet). Also had to coat that damn dash bracket because it was very rusted...just a shame it won't be seen since it's under the dash.
AlbertD
Tucson, AZ
Made a custom radio delete panel. Going to add a red/white/blue stripe vertically down the middle and a Carrol Shelby sig running horizontally across it. Should look sweet. Also, need to add a switch for the line lock and possibly another for activating the heat exchanger pump and fans in between track runs.
photo (6) by albertericd, on Flickr
AlbertD
Tucson, AZ
ZGrand
Georgia
Installed a set of FRPP chrome cam covers. So much better than those ugly stock covers!
