On3 Coyote dyno vid
slagburn
Disregard the 1200hp part, that's SAE corrected which is rather 'generous' up here.. I think a more realistic number would be around 1120 rwhp at sea level.
UltraKla$$ic
PERENNIAL WAXXER
Louisiana
OMG. a freakin BEAST of a sleeper look on the outside. You're gonna blow the tires off the rims!!
CPRsm
Weak sauce. Turn it up till you smell coolant and back it down a touch :beerdrink:
wbt
Impressive. Those On3 kits aren't worth a damn are they? ;)
Mr. Stallion
TPS Motorsports
On The Dyno
What turbos were they? On3 or did you upgrade to better units?
Also what fuel system? Stock engine?
slagburn
So what did you have to upgrade on the kit?
Nothing. It's a stock kit, now with the bigger on3 turbos. The 60's went 8.86 and 157.7 mph, looking for a little better this season with the 67's. I did have to have a spacer made to clear the optional .96AR hotsides on these turbos. The smaller housing options fit without a spacer.
slagburn
Any vids going down the track in this beast???????
Sure Darren, did a 2014 highs and lows compilation.. trying to get it moving on no-prep, blowing a motor (not enough injector and dumbass driver) and the quickest runs from sea level and up here.
