cavero
NoVA
started on this project
So far those look pretty good (a lot better than I expected a projector retrofit to look)! I'll definitely be interested to see how they turn out.
Which projectors are you using?
HitandRunDriver
Amateur Goon
Orange, California
Thats what I do too and all I get is streaking! I almost threw the bottle in the trash the last time I tried to use it. Ended up having to grab another QD I had to clean up the Sonar QD. I even tried using several microfibers to make sure that it wasn't just being spread around more.
How humid is it out when you use the Sonax?
Riptide
Will work for Mustang.
Montucky
I think the stainless Pypes I am looking at is only $300. If the resonators don't work maybe try that, and sell yours?
FYI
I had the resonators welded into the system today. The tinny rattle/rasp noise is gone now.
Whether a stainless H would've fixed it too I can't say at this point.
Whiskey11
SCCA Autoscrosser #23 STU
They aren't exactly designed with drag racing in mind. They'll do it, but they focus on dry handling grip more than launch grip. They are a great DD tire as they DO have good grip under braking and for turning, the two most important things in daily driving to avoid ending up in accidents!
weather man
Persistence Is A Bitch
MN
Woke her up after a long winter slumber. I decided to use Lucas E85 fuel stabilizer, and it worked as advertised. Car idles perfectly.
TRC51
Well on the test drive home they're certainly grippier than the conti DWS that were on before. Need to get a good heating in them
I thinkmy conti DW's actually hooked better than my MPSS' s.... and they were narrower. I haven't played with the tire pressure yet though.
