Five Oh Brian
Mustang Guru
Consider how much better it would be with the 3.15 and not having to go into 4th.
Sure, but if I go any faster, I'll need a 6 point rollbar and I'd lose the use of my back seat, so I'll keep my "slow" 4.10 gears for now.
5.14 gear FTW!!!Heh.....if you are going that route then why not put more gear in it and maybe shoot to shift into 5th before the end? May as well make use of as many gears/shifts as possible and get your money's worth from that trans.![]()
KrisR, your car looks great on those wheels/tires. Can't wait to see how it runs now, especially with the converter. I'd expect your car to run quicker than mine.
For a brief moment last year I considered 5.14's, but then I regained sanity.
I know some of you think I messed up by going with 4.10's and maybe I did, but my car is the quickest NA Coyote/6R80 at either of our local tracks. I know there must be plenty of faster ones out there, but I haven't seen one around here.
Sent from SYNC in my '14 Mustang GT...
I have tuned several that are and they all have less gear.
Here is a pretty decent list of N/A cars with mods and times: http://www.modularfords.com/threads/185818-Bolt-on-2011-2013-Mustang-GT-5-0-Drag-Racing-ET-List
Crossing the stripe in 3rd or 4th doesn't seem to matter to a tuned/stalled 6R80. The extra shift is only a few milliseconds, and with a 5,000 rpm stall converter, a WOT upshift never drops the revs below peak torque.
That is the crux of the argument and simply not true. The extra shift takes longer than milliseconds and if the converter is locked, stall speed doesn't make a difference. The only time that stall speed matters with a lockup converter is when launching the car.
...and regardless of rear gear in the car, RPM drop between shifts is the same.
The key things to look at are how long the car is in the optimal RPM range, when is the right place to lock the converter, and where in the RPM range the car is when going through at the end.
If one figures out the formula to the above they will be successful with the right combination of parts and tuning.
Your car runs good but I think it could be better is what I am saying.
Have fun and good luck. I'm going tomorrow to test mine out!
Good luck!
I'm heading to the track in about an hour to see how consistent the car runs hotlapping (today is a test n tune session). An 11.49 would really make my day, but I'm only expecting 11.60's and 11.70's based on today's weather.
Is Bremerton any less strict about tech? Do they prep well?
