centrifugal vs root
stangboy901
I have a question I really need answered I have a 2005 mustang gt and I'm trying to see which would make the most power for a stock block with stock 3.55 gears should I go with a rooted supercharger or a centi style someone please respond and should I upgrade my gears to 3.73 or 4.10 and what are some other upgrades could I do for more power with the supercharger
jayman33
Both can max out your stock block. I personally like PD blowers and the R2300 has been extremely popular with our customers.
Vendor Specials Limited time deals from our sponsors.
please be more observant of the forum you're in before posting
moved
additionally, learn to use punctuation.
either style a "roots", not rooted -that's for plants, or a centri style can make more power then the stock block can handle.
use the search - many threads on these topics
weather man
Persistence Is A Bitch
MN
Jayman is like, Fuck!, is this the best I get in my house!
go302
Tits McGee
Oklahoma City
Don't wasste your money adding power to your stock block. You're just gonna lose to a slow car anyway and blow your motor in the process.
eighty6gt
Roush 2300, leave your gears and everything else alone, run 9-10 psi or so depending on what fuel you can get, you may need a fuel pump wire upgrade, have fun.
blownGTvert
Zeeland, MI
Another vote here for PD blower. For an "off the shelf kit" my choice is a Roush 2300 or Whipple 2.3. A less expensive option is a DOB kit that uses OEM ford parts.
MassMustang
Southeastern Mass
Welcome to the forum!
Do you have a budget in mind as well as any specific shortterm/longterm power goals?
I'm guessing you're looking at a used Kit like an M90 or Vortech.
tjm73
of Omicron Persei 8
Rush, NY
Do you want it to build power as you build up rpms, or do you want it to make boat loads of torque early and carry it over a large rpm window? If the answer is the latter, positive displacement is the way to go.
Department Of Boost
Alpha Geek
They newer blower are not "roots" blowers anymore. If you want to group all of them together call them Positive Displacement blowers. The category of Positive Displacement blowers is made up of Roots Improved (much better than roots) and Twin Screw blowers. And Roots Improved can technically be paired down to Roots Improved and TVS. Examples are:
Roots Improved TVS
-Roush TVS
-Edelebrack E-Force
Roots Improved
-2007-2012 GT500
Twin Screw
-Whipple
-Kenne Bell
Check out this option(s). Best bang for the buck out there:
http://departmentofboost.com/products/2005_2010_mustang_gt/gt450_stage_I.htm
http://departmentofboost.com/products/2005_2010_mustang_gt/gt450_stage_II.htm
http://departmentofboost.com/products/2005_2010_mustang_gt/gt450_stage_III.htm
We also carry Roush and Whipple. But unless you are planning on spending the big bucks building your motor, upgrading your fuel system, etc the GT450 kits above are a better option.
