What The Fuck Happened There Thread!?!
weather man
Persistence Is A Bitch
MN
Been a few times I have seen mustang carnage pics and not a really good way to share.
So if you see a mustang carnage pic that stands out in a WTF! kind of way, post it up!
Saw this over on SVTP, guy trying to trouble shoot fuel issue. Zero gap on the plug. The detonation divots are impressive!
[/URL]
Wicked GT
OCD with ADD...
Omaha, NE
Here is one of mine from a previous stang... Valve spring broke, dropped the valve in to the cylinder, broke off valve stem, and shot the valve back through the hole it came from in the head. It really F'ed the head and piston up but gave me the opportunity take a 1973 2 barrel 351 Cleveland and turn it in to a .10 bored 4 barrel Boss 351 motor so in the end all was good.
Fullboogie
King of the Ski - OG Jr.
Houston
When fuel pump filter socks go bad and drive up your FPDC to 100% at 4,000 rpm (my car):
Wicked GT
OCD with ADD...
Omaha, NE
What the heck is inside the filter? Looks like potato chips or some kind of buildup?
Fullboogie
Houston
The filters themselves disintegrated. I bought the '07 GT500 in 2012 with 300 miles on it. Apparently it was the same tank of gas from the dealer, and it just sat there in a guy's garage for 5 1/2 years. The tank was full of gooey shit too. Had to replace everything - pumps, socks, lines, tank, etc.
weather man
MN
Hard to believe it didn't take the motor! Wow!
Fullboogie
Houston
It would have if I hadn't by change been monitoring FPDC's on my Interceptor. Pure luck!
irishpwr46
Official Site Vandal
NYC
back in my riding hard days, took the banshee out for a ride, and something went wrong. i dont have the original pics anymore and this i all i could find
weather man
MN
Man, I saw a lot of shit like that when I worked at the powersport store.
claudermilk
SoCal
...so you're saying this is likely what Darren's fuel filter looks like?
:poke: :buffer:
Steve@Tasca
Not a Mustang but it's current carnage, just installed a rebuilt turbo on my sons 2000 ZX3 and found out that the boost line was previously mis-routed so an engine that was solid for ten years at 8-10psi got spiked to 15psi on the first test hit.
No issues with the old worn out turbo but with one that actually works?
The result was two snapped rods and five holes in the engine.
cbass
Rochester, NY
Wish I still had the pictures from my neon clutch. I was doing a second gear pull, and when I shifted to 3rd, it spun on a bridge gap, while spraying, all the way across the bridge, and then I hit a bit of grippy pavement on the other side. The immediate abundance of grip vs the high speed of the rotating bits sheared all 4 of the tabs of the clutch between the center section and the bit that holds the clutch material. I stopped running stupid grippy tires on that car after that.
05moneypit
Grove City PA.
Just a few.
Auburn diff.
Paschel cam gear failure results.
Can't remember the drive shaft brand.
4R70 direct clutches.
Steve@Tasca
The Buick 430 piston I've been using as a pen holder for the last 20 years,
Fullboogie
Houston
This is from my (former) Yamaha ski after its best top speed season. Ski ran perfect, compression was perfect. I only discovered this when I went in to re-ring it. Chunk must have blown out the exhaust. You can see where the ring hung in the exhaust port, pushed up on the ring land, which caused the middle ring land to break.
weather man
MN
Head on, not fatal. Passenger broke both feet. Yowser!
fdjizm
Drag Queen
Reminds me of someone...
46Tbird
DFW USA
Stock, untuned 2012 GT with cracked ring lands on #8. Ford warrantied it out, no problem.
