retfr8flyr
The Old One
Thanks guys for all the kind words. I have had her for a while now but I will never give her up. I also love the color and you can't get it on anything anymore. Tungsten changes color depending on the sun and the angle you are looking. You can even see it in the pics, they were all taken at the same time but the different angles make the car color look different.
I don't have any pics of the bracket but I can take some if you want. I had the Scott Drake hood pins, with the bracket that mounts under the radiator retention bracket. Like these. https://www.youtube.com/watch?v=lxna0PPOlng This restricted where I could mount the Aerocatch latches. They are not bad to install but with my glass hood I couldn't use the piece that goes on the underside of the hood. Mine are just screwed to the hood itself. It's a little intimidating cutting a big hole like that in your hood but if you measure correctly and take your time, it's not that bad. I have a small air saw that I used to cut the holes and it worked great.Car is awesome. Love the color ;-) The aerocatch hood pins look great. Do you have a pic of where you mounted them underhood? Were they hard to install? I have a set of aerocatch pins; but I have been too chicken to cut the the holes in my hood. Where you mounted them, they would blend in with my blacked out stock hood. I also have a set of UPR pins. Can't decide if I should do pins or not. I just get a little nervous when my stock hood starts flapping above certain speeds.
