Riptide
Will work for Mustang.
Montucky
Ran the car with the VMP setup last night. Best pass was a 10.9@128. I had some issues with the burnout and spun on the launch a few times due mainly to me being out of practice. Sixty foot was 1.7.
The car was making good power trapping high 120s even in the 90 degree heat. No hot lapping however I was still impressed with the intake temps. They only started pushing 130 at the very end of the attempt.
Super happy with the setup and went a full 1.7 seconds faster than I have ever been before.
Redline727
"I wanna go fast!"
RVA
Installed a McLeod SS clutch line, did it's 3rd oil change, and hit 1500 miles on the drive home from the shop. Only took a little over 2 years to do lol.
Install went almost as easy as it could I suppose. I just screwed up one time haha. Made a rookie mistake and left the cap off the reservoir when I disconnected the line from the pedal. And then raised the car up to disconnect at the trans and lost a little more fluid then I needed to. But I caught it and put the cap back on. I even went to the hardware store and got a rubber stopper and 1/4" barb fitting for my buddies Mitivac and made the "Ford vacuum bleeder" to bleed the system per Fords bleeding procedures. Worked like a charm and clutch feels great!
Dude, that's huge. Whole nother world, huh?
Riptide
Montucky
I was ecstatic after breaking into the tens! [emoji3]
I bought a bunch of ms109 and was going to get a tune for it. Not sure if I need it now after trapping 128 on pump.
droptopstang
Naples, FL
I washed the stang today while my son washed his corvette. I love daddy and son car days :)
bigmike06GT
Put down a big deposit for my builder to start ordering parts, Forged shortblock,, bigger injectors, GT500 fuel pump, 1 pce driveshaft, driveshaft loop, smaller pullley and a few other parts.
NickD87
Toronto, Canada
Installed a 99-04 bullet or mach 1 shift knob on the mgw to replace the cheap AM ball I had. And started data logging with Lito.
Gabe
Whippled Coyote
You should remove that sound tube ^^^, post up detailed pictures on how you did it in several threads, then start a new thread about how you turned part of it into a penis extension that you're now offering for sale
