swflastang05
Back for More
How did you attach the shoulder straps to the cage. Can you take a pic?
Also you deleted the stock belt? Are5 points legal on the roads? I thought they were for track only.
I just wrapped them, my bar has a boxed in area that you can't really see in this pic but I believe it's intended to prevent the shoulder belts from moving laterally on the cross bar. The stock belts are still there, mostly since it's a major PITA to get those side panels off with the bar installed, not worth the effort for me lol! I also wasn't sure what to expect if I removed the OEM lap belt with the sensor that tells the car when the belt is unbuckled, I didn't want to hear it beep non-stop so I plugged the OEM shoulder belt into it for now. I'm testing everything out right now, if all goes well I'll make it a little more permanent when I install the new seats later on. I don't drive my car much on the street, just for a weekend cruise, etc. so I'm not too concerned about it.
11.5 around here
Yes IIRC the current NHRA rules require anything (non-convertible) going 11.49 - 10.00 to have a 6 pt bar.
Good article there. It covers the point of the anti-sub strap(s) nicely. Basically: to keep the lap belts in position over your pelvis to your squishy bits above it don't get crushed into paste. I went for a 6-point setup in my car and they are not uncomfortable.
^^ Yes it is, and I/ followed the manufacturer's instructions with my harness to the letter.
