travelers
Took the A/C out.
And a few other things from under the hood it looks.....LOL
Took the A/C out.
4300k has better output than 5000k. 5000k is brighter thought.
#sciencedWat?
Wat?
#scienced
After the wrap shop finished the install, my driver's window doesn't work. When he pulled it out of the garage when we picked the car up, he had a tech take the door panel off. He unplugged the harness from the motor and plugged it back in and the window worked. Three days later it stopped again.
I spent two hours today trying to get the damned thing to work and had no luck. (The wrap shop offered, but I figured it'd be easy enough I'd save the time and just do it myself) I ordered a new switch, hopefully that's all that's wrong. I wouldn't think the regulator would go out on a car with 23K miles.
Hell yeah Hamilton! I'm interested on how that works out and if it gives you any gains.
I got lucky with this. A $30 switch from Ebay, 20 seconds to swap it out, and the window works again.
Glad to hear it was just the switch.
I'll let you know if I see a difference, though won't be going back to the track until at least spring, but now I will launch with a little more confidence. Also getting a BMR uca later this week, and swapping my old lca for bmrs soon too.
Was a little upset that a HCI ls1 t/a pulled 3/4 car on me on the highway yesterday, and he had a passenger! May be time to start worrying more about weight, take the sub out of the trunk etc
I had a mean sounding T/A picking on me on 270 near 40 the other day. I didn't give him a second look since my wife was with me. I wouldn't be surprised if it was the same one.
I want to get to the track on some DR's this fall...but after the wrap and with the baby coming my car allowance has been taken away! I don't know when I'll ever make it back.
Went to Renegade raceway Friday night. Best pass was 12.4 @ 113 on my new slicks. Decent 60 ft I suppose at 1.78. More power? I would really like to get my 60 ft down to the 1.5-1.6 range too. Any thoughts? Car is bolt on 2012 6sp
Sent from my XT1080 using Tapatalk
Nice! Yeah my car has a full suspension, lowers, adj upper, adj panhard, relo brackets, koni oranges, steeda springs, dynotech d/s etc. Are you a 6spd as well? What rpm are you launching at? I was experimenting around 3500-4500 rpm. Tire pressure at around 17 cold. 28-11.5-15 M/T ET Drag.I was cutting 1.62 on et drags with lower control arms relo bracketS and mild bolt ons.
