Saleen304
Pretty much a Saleen Parnelli Jones motor with E85 2.75 pulley and 10% OD crank pulley. 10.7:1 compression, stroked, shorties, ported heads...
pacettr
PJ Lover
Yukon, OK
Nice numbers! I have a 3.0 pulley currently. Adding a 10% lower and swapping to e85 over the winter myself :rockit:
Saleen304
Thanks! I actually just stopped by the dyno shop and there was an error with the rpms so the hp was not calculated correctly. Final numbers are now 749/671.
pacettr
PJ Lover
Yukon, OK
That sounds pretty optimistic for a Saleen blower. Need some track numbers now!
I find it hilarious you needed two fatasses on the trunk to keep the tires from spinning on the dyno. Awesome numbers! :rockit:
Gabe
Whippled Coyote
Got the girlfriend's new '13-'14 TVS blower installed today, with the new '13-'14 GT500 injectors, new JLT 123mm CAI, and the FRPP twin 65mm TB ... 17 psi, 20 deg timing, SAE-corrected 643 rwhp, 608 rwtq, uncorrected 652/617.
She's happy :)
Pics and video coming.
tigerhonaker
TN
She's happy :)
Gabe,
Nice going man. :patriot:
T.
AlbertD
Tucson, AZ
She's happy :)
Awesome, she must be really excited!
BAP or just injectors? Smaller pulley on the blower to reach 17psi?
Gabe
Whippled Coyote
No BAP.
Seller insists that we have the stock pulley on there, tuner thinks it's smaller since the stock one usually only puts out 15psi supposedly.
Injectors duty cycle maxed out at 94%, fuel pump duty cycle maxed out about the same, 93-94%
So we're pretty much done unless we go bigger injectors and a BAP
AlbertD
Tucson, AZ
No BAP.
Gotcha, yeah I think it has a smaller pulley on there. At my DA I am only seeing 13 psi on the stock pulley with a calculated 2 psi loss. Stock should be around 15 psi.
Look forward to the vid.
Riptide
Will work for Mustang.
Montucky
i'm just old i guess, but i like how it looks now better.
I'm 39 so old too. I like how it looks now with the 18s. I'd never go larger than that and if I could squeeze 15s on all 4 corners without redoing the brakes I'd have done it already on this car.
Gabe
Whippled Coyote
The vid :)
17psi using stock pulley and a lightly ported elbow
SAE corrected numbers: 643 rwhp, 608 rwtq
Uncorrected numbers: 652 rwhp, 617 rwtq
The "before TVS" numbers and the SAE-corrected "after" numbers:
Uncorrected:
Installed:
Old and new:
o2sys
Swapped SLP Loudmouth to Pypes Deletes. Pypes are much louder, amazing how just a different type tips change he volume and sound!
o2sys
^crazy! I have the slp. Muffler diameter the reason?
I think the doubled wall tips on the SLP and the fact that it's only 3.5" and maybe even smaller ID makes them slightly quierter.
The Pypes are noticeably louder and it burbles more during engine braking.
Doug M
Fast Cars & Freedom
AL. Baby
Pipe diameter, I meant to say. Lol
Not muffler.
Anybody want to trade, slp for pype bombs? Lol
