Official 1/4 MILE ET RANKING: 3V ALL MOTOR
Wet197
Mild bolt on 2008 mustang personal best
Mods: CAI, 4.10 gears, underdrive pulleys and skinnies, 12.86 @ 106!! Auto trans running Nitto NT555r drag radials
NickD87
Toronto, Canada
05 Gt, 3650, stock heads, hot rod cams,
lindertw
NoVA
great job NickD87! cooler air and less weight (seat removal), right?
NickD87
Toronto, Canada
Thanks
You and fdjizm are my inspiration
I got a new tune from lito (was rich before, I still need a wideband)
Cooler air but also a cool track (private rental with less then 10 cars)
took the passenger and rear seat out, left hardware in as it didnt seem to weigh much, I did not get around to dropping the sway bar as you suggested but I will be next year along with probably skinnies
I think this would make me #35, Im gunning for your spot next year lol
Hansonb625
06 GT
3650 tranny
Hot rod cams
Stock heads
4.10 gear
281 ci
Mt et streets bias
NA
csracing
SE Wisconsin
new PB on new engine build
I need some new parts and tuning yet as I'm maxing out the pump and injectors (going lean) but here are my time slips from last weekend. Please add me to the list.
2007 Mustang GT full interior - no weight reduction
TR3650 5-speed
305cid 3V (big bore Cammer block)
Ported & milled heads (porting done by myself)
Lunati 21270720 cams (109 ICL)
4.10 gears
28x9x15 MT ET Drag tire
obsrt86
My mod list:
JLT S3 intake
Steeda CMDP
Pacesetter LT w/ off-road h-pipe
SSS Axleback
Summit Racing Pulleys
SCT X4 w/BAMA tune
FRPP 4.10 gears
Suspesion:
BMR LCAs
BMR panhard bar
J&M Adj. UCA w/J&M bracket
BMR drag springs,
BMR Relo brackets
Tire setup:
SVE 17" skinnies
275/60/15 Nitto 555 Extreme Drag on 15x8 Summit wheels
07droptopgt
Texarkana Ark.
timeslip
2007 mustang gt convertible, cold air, 373 gears, automatic 5r55, cooper zeon, p285/40/zr18s, sct 90mm cold air tune, flowmasters,
Boss281
New Windsor, MD
Yep, next season hopefully. After the 11 second runs the 3650 bit the dust, and I had it rebuilt with a beefed up version from Hanlon Motorsports (26 spline input shaft, hardened internals, etc). I'm really curious what a stronger trans would give me with the gas pedal planted and 6500rpm shifts. I think a 11.5 completely doable. We'll see.
ponys197
Troy OH
2006 Mustang GT Premium Tungsten Grey
4.6L 3v 281
TR5r55s 5sp Auto
JLT Series 3 CAI
3.73 FRPP
Stock Pirelli's P Zero's
Mod list
Brenspeed Tune
X4 Tuner
SR Performance LCA's
SR Performance Strut Tower Brace
JLT Oil Separator
Appearance Mods
MMD Hood Struts
MMD Painted Side Window Louvers
Ceramic Window Tint
Added 2nd timeslip within 2%. I have another 13.4ish somewhere but this is close enough.
Found my fastest slip - 13.375 @ 102.46
duststang
dang you guys are rolling out. my best was like 13.4 @102 with Auto CAI and tune.
NickD87
Toronto, Canada
4.6L 3v 281
TR5r55s 5sp Auto
JLT Series 3 CAI
3.73 FRPP
Mod list
Brenspeed Tune
X4 Tuner
JLT Oil Separator
Appearance Mods
MMD Hood Struts
Ceramic Window Tint
Do you know what the DA was for that day? Or just track elevation?
I was running around 106 at 1000' with just intake and tune, maybe look into data logging to see if you can get some more mph out of it
ponys197
Troy OH
Track elevation is 492 ft above sea level. I dont know what the DA was those days. Both days were about 68 / 69 degrees out .
I didnt datalog there but I do have 2 datalogged WOT passes on a local road running 2 different tunes. I can send them to you if you want to look at them.
NickD87
Toronto, Canada
I dont know a thing about tuning, (I leave that to Lito) but I would send them to your tuner to look at
