Will AM Bullitt Chrome wheels hold up to high horsepower?
raredesign
Rochester, NY
Good day all.
I found on this thread that the American Muscle Bullitt wheels, even though they look awesome, may be cheap Chinese-made wheels.
Please note, I absolutely love American Muscle and bought WAAY too much stuff from them. :clap:, but I am just trying to find out if this purchase is appropriate for my particular setup and use.
After many many threads on here and the interweb, I "think" I have decided on the Mickey Thompson ET Street S/S in a 305/40/18.
I am hoping that the wheels will hold up as I am unsure what it takes to crack at the bolts or shatter from forces on the strip.
While this will primarily be "hopefully" an ~850rwhp DD, I would certainly like to hit the strip at some point. Anyone have drag strip experience with these rims?
Thanks all.
Cheap SR cast chrome wheels, held up fine for me for a few years.
I have the same 18 x10 AM chrome bullitt deep dish wheels as you have in ur link....and on all 4 x corners. I believe they are aprx 30 lbs each. I only have 390 rwhp. With deep dish rims the spokes are inboard a bit, which imo, may provide for better overall support, vs spokes that start at the outer edge of the wheel. I don't think you will have any issues. They have a lifetime warranty on em for structural issues. Zero problems with the TPMS sensors.
I did have an issue with one of the 10" rims..with a real slooow leak. Took it to the local tire shop, and we stuck it into a big tank of water. Up came the tiniest stream of bubbles I have ever seen... on the barrel, 2" from the edge of the inboard edge. No big deal, AM sent out a 2nd rim asap...and also paid for the invoice from local tire shop to swap the rubber from defective rim to new replacement rim.
The TPMS would trip every 4 weeks, once pressure was down to 24 psi (= 75% of the 32 psi ford recommended tire pressure on the sticker on the door post)
raredesign
Rochester, NY
Thanks for the feedback. So the TPMS was only tripping due to the leak over 4 weeks, and after you got it fixed there were no problems?
Sky Render
Stig's Retarded Cousin
NW of Baltimore, MD
If you have 4-pot Brembos up front, you will have difficulties getting some of the 18" AM wheels to fit. Basically, you'll need to find a shop that can balance the wheels in such a way that you won't have weights hitting the calipers.
raredesign
Rochester, NY
I'll have to keep that in mind, as I plan on upgrading the brake system at some point.
