CammedS197
Not sure but probably in wrong area delete if not allowed. But thought this would be the best place to ask to get info, thanks. So basically what I want to do is replace everything that deals with suspension and brakes and make it all like new again but also upgrade. Now I know the basic parts to replace like control arms, k member, a arms, all rear axle seals and bearings and hubs and rear diff cover. I daily and like to drive aggressively on the road and will like to autox once a year. I spirited drive in an abandoned construction area from years ago only had roads put in and makes for fun spirited driving.
Current mods on car are BMR LCA, BMR panhard bar adjustable, and SR springs which will go away.
What I currently have on list:
-Ground control coil kit
-BMR sway bars
-BMR LCA relocation brackets
-BMR k member standard motor mounts
-New stock calipers and centric premium rotors (purchased) and stoptech pads (purchased)
-SS brake lines
-A arms whatever is recommended
-New hubs
-upgraded rear diff cover
What else am I missing, that's all I can think of from the top of my head. I know there should be plenty more in there to freshen up everything. Just want all fresh and new and why not drop weight and upgrade while at it.
Thanks and sorry if in wrong area.
-BMR sway bars
-SS brake lines
-New hubs
