Matt,
Nothing's been done yet. The
wet ZEX kit was ordered and should be in this thursday or Friday, so I don't know if we're installing the setup Friday or Monday. They keep the GT40 pumps in inventory, as well as the Brisk plugs.
When they install they'll put it on the dyno and pull
"one or two degrees"[end quote]. However, I've asked Doug at Bamachips for a nitrous-specific tune. Alternatively, I'm thinking of using my 87 tune instead of my 93 tune so as to start off with less timing.
I've bolded, underlined and italicized the word wet above because my understanding is that there is somewhat of a difference between a wet kit and a dry kit. This ZEX kit come with a computer "controller" that only injects nitrous when the TPS is at WOT, and is constantly measuring the nitrous pressure so as to prevent dumping fuel into the engine when the nitrous runs out. This controller also keeps the AFR at whatever it set at when the system is set up.
Can anyone explain the differences between a wet kit and a dry kit? Is the wet at WOT only and the dry a progressing/progressive stages thing?
Marc,
I've had the zex wet kit before and it is a respectable kit. The kit should be jetted rich enough from zex ( most companies jet their kits a little rich to cover their ass) and be safe. The only thing I worry about is pulling only 1 to 2 degrees of timing with a 125 shot (even if it is rated at the flywheel). A common rule of thumb is 2 degrees for every 50. This rule however is not set in stone and should only be used on baseline tuning when it is on the dyno.
