ARP everything?
Wes06
he must have been given the news of testicular torsion earlier....heh
roberts
Bonne Terre, Missouri
I'm turbo. If u are a blower u will brake the crank about at roughly 800-825!
JeremyH
3V Fuel Guru
Virginia Beach
It has to do with bsfc of the setup which is essentially how efficient the combo is at using fuel to make power. I run around 11.9:1 afr on 93 and my e85 tune was done on lambda but my wideband doesn't know I'm using e85 so regardless of fuel and tune I'm running I'm looking for the same reading on my wideband. High 11's to 1 seems to be a good spot for a turbo cars fuel needs. Parasitic drag and of a belt driven roots/screw blower and iats changes the bsfc of the engine and requires more fuel to make the same power.
Based on my experience, the afr sweet spot for a 3v with compression in the 9-10:1 range are as follows, keep in mind ve, iat overall boost level, rpm and timing etc play a role in this too:
12.8-13.0:1 for na
11.8-11.9:1 for turbo
11.6-11.7:1 for centri
11.5-11.6:1 for roots
11.3-11.4:1 for screw
Adding a little more fuel on any of these setup can account for some higher iat's or little more timing or some safety margin if needed. This isn't an exact thing and of course these numbers vary from setup to setup and tuner etc.
roberts
That's good info Jeremy!
Idk I let the tuner work his magic didn't ask no questions!
After the 20psi and 878hp he looked at me and said do u want more! I said nope that's good. He said we could of added 2 degrees of timing and make about 950hp. My car is also low timing 16 degrees.
Heaten m90
That makes sence, its not an actual A/F sensor but a lambda sensor. Its simply measures the absence of oxygen and uses that valve to calculate AFR based on the stoich valve of whatever fuel youre using. So he simply needs to reprogram for ethanol instead of gasoline.
Im still confused as why the AFR would be different depending of the compressor. I mean clearly a roots style blower would require more fuel due to parastatic loss but why would the mixture change? Unless the extra fuel is being used for cooling or possibly in dealing with the flame front or fuel/timing curve characteristics maybe? None the less great info, thanks
JeremyH
3V Fuel Guru
Virginia Beach
Yes on a real basic level its cooling to prevent detonation. This is how I understand the whole concept. On a boosted setup you have two things to consider. How good is the engine at making power (moving air) and how good is the compressor is at compressing air (making power). Friction and drag will affect the motors power output at the shaft, and the efficiency of the compressor/intercooler will effect how much additional power you can add. The definition of brake specific fuel consumption is how efficient the setup is at using fuel to create a power output at the shaft.
"Lean is mean" if you can lean the afr safely you can make more power to a degree (this is creating more heat/energy during combustion to make that power). Since a bsfc rating is how efficient the setup is at using fuel to make power, then in turn you would be able to achieve a leaner afr or more efficient stoich ratio for that better bsfc setup. You can safely tune for it to make more power, they really go hand in hand. If you couldn't do this and every boosted setup had the exact same acheivable stoich to make the best power then they would all consume the same amount of fuel with the air to make that power.
So that's the other piece you mentioned, not all compressor have the same efficiency. Compressor efficiency is measured in how much heat it puts into the air while compressing the air. The hotter the air charge the less air there is per volume and the more fuel is needed to prevent detonation since that heat translates to more heat during combustion and fuel is what is used to cool things to prevent said detonation. The cooler the air is the denser it is per volume and less fuel is needed to keep things happy. So cooler air and leaner fuel makes more power. Notice I talked about air density and volume, this plays a role as well. This is why setup A might make 475rwhp at 10psi and setup B might make 525rwhp at 10psi. Your effectively moving more air at the same pressure. We like to measure compressor efficiency by this a lot. How much hp per psi does it produce. On a 300hp engine for both setups setup A is making 17.5 hp per psi and setup B is making 22.5 hp per psi. A belt driven compressor is always spinning and creating heat and you have to bypass this air when not wanted depending on engine load. Not the same for a load based compressor, when cruising low load there is no compressing taking place and no bypassing air so no heat being produced. We already talked about drag.
Last part is intercooler's efficiency is how well it can cool back down the heated air. A2w is more efficient than a2a. Pd/screw blowers always use the more efficient cooler as its what fits and goes better with the heat production. Centri/turbo setups most often have a2a as they can get away with the less efficient charge cooler as they produce less heat to compress the air.
My twin turbo setup was able to produce 610rwhp at 10psi on e85 which comes out to almost 30 hp per psi. How is this possible? Its all in the efficiency of the entire setup. Engine, fuel, compressor, intercooler. I have good ve in the motor with intake/cams and compression/light weight rotating assembly. The turbo setup and intercooler had ambient iat's so no additional heat was in the air. The increased volume of fuel used with e85 allows for additional cooling for leaner afr and more timing as well as the power produced from the more oxygen in said fuel.
Same way Travis is making a lot of power for his boost level. ;)
Heaten m90
Very informative, had i read this before selling my supercharger i would've kept the intercooler and custom fabricated the intake manifold without a doubt. the cooling benefits of E85 are great and i plan on running it but im not looking forward to the costly fuel system requirements. Thanks for information.
