Mustang dog
Seem like a lot more than a bit, looks terrific though. Is there any type of clear coat you could spray on that wouldnt change the polished look?
I didn't use any clear coat on the Al, only the steel pan. I was worried that, that could yellow the AL. I'll just have to be a bit dilligent on keeping it clean.
Kipp07GT
Slug Box
York South Carolina
Finally got the rest of my Air Ride kit in. Finished it up in the nasty cold. But it looks great so far. Still have a ton of work to do. The Roush rear bumper is getting painted and should be on soon to replace that god awful junk thats on there now. Exhaust is in so I will have it installed once the bumper is changed. IMG_0348.jpg IMG_0351.jpg
MilehighGS
Colorado
Pulled it out of the garage and discovered a nice little leak..........looks like brake fluid.....adding that to the list along with my forged build
Sent from my SM-G950U using Tapatalk
Gabe
Whippled Coyote
Walked by it as I pulled out the snow blower and went outside for a couple hours to clear the driveway and make a path to the generator, oil fill, and propane tank.
I'm ready for the summer.
JJDAG
Queensbury New York
Did the exact same thing 3 times today.
bujeezus
Alabama
Discovered mine has a mysterious coolant leak as in I don't know where the fuck it's leaking. All the hoses look good and nothing is accumulating under the car. Where else do I need to look?
Gabe
Whippled Coyote
Is it draining down the back of the engine, onto the trans?
bujeezus
Alabama
I didn't check the back of the engine. Is that where it shows up when that line under the intake is leaking?
ghunt81
New parts on old junk!
Clarksburg, WV
I have an itch to drive my car and the weather is total shit....dammit. How long til spring?
Gabe
Whippled Coyote
Yeah, the engine has a slight tilt toward the back as it's installed in the car, coolant will find a way out down the back
dark steed
Resident noob
Winder, GA
Look in the valley. Sounds like your heater tube assembly is leaking. Mine did the exact same thing
dark steed
Resident noob
Winder, GA
Was it a simple fix as far as parts?
Yes, I ordered the part from Tasca Ford and my daughter actually replaced it! (She was borrowing the car at the time).
It does require removing the intake.
jlmotox
Installed a new spoiler, took a chance and it paid off. Got the spoiler off Amazon pre painted for $129, came in 2 days and the paint matches great!
ghunt81
Clarksburg, WV
Is that the GT500 style spoiler? I keep going back and forth on that one, can't decide if I actually want to get it or not.
Got a link? I hate my CS spoiler, it's freakin' massive. I can only see out the top half of my back window via the rear view mirror.
