Need help with finding flow formed rims
stang_gang
I want to go with a square 18x10 setup
So I’ve been looking at these but they’re 18x10 +35 https://lmr.com/item/WK-177903/mustang-sve-r350-wheel-kit-graphite-19x10-05-14
And the rims that apex make that are 18x10 +43
I’ve looked at a ton of fitment threads but I need to know if 18x10 +35 will fit all around without poking out of the fenders?
I would like to go with the SVE setup because it will be about 500 bucks cheaper if they will fit
oldVOR
Northern Virginia
Are you looking for 18's or 19's? You mention 18's but the link is for 19's.
Anyway, with 10's and +35 and depending on tire selection, you will probably have poke on the rear and maybe the front depending on camber settings.
I've had ForgeStar 19x10 ET42 w/285-35 PS91 (11.4 section & 10.4 tread widths) and they sit flush on the rear and slightly inset on the front w/factory camber settings.
I've also had APEX 18x10 ET43 w/285-35 R-S4 (11.7 section & 10.6 tread widths) and they sit flush on the rear and slightly inset on the front w/factory camber settings.
Please review the tech posting rules before posting in the tech sections.
Moved
stang_gang
Yeah I was looking for 18s but since those are so much more cheaper I wouldn’t mind running 19s. They say they’re meant for 2005-20xx mustangs so I figured they might fit but I read up on fitment and I thought with a 10in wide rim you’d want +45 mm offset so it fits correctly. Any other suggestions?
My car is completely stock just saying
stang_gang
So bought the r350 flow formed rims from lmr and I’m impressed. They got the measurements spot on for offset etc. look at this fitment. I’m on stock suspension and I have 0 rubbing so far.
06JET
West Bend WI
Looks great. How about the fit now? Any rubbing during turning or while hitting bumps in the road?
