Sequential turn signals
Dwain Pate
Hi all. I have a 06 base that I installed sequential wiring kit. They blink faster than I would like. I realize the flasher is integrated in the SJB. Does anyone know if dealer can change the speed to have a little longer pause between flashes?
MADGT
USA
I suspect the speed is dictated by the aftermarket type/model of sequentials you installed; doubt a dealer would even touch them,but the some guru chime in
08MustangDude
Resident Fuktard
Blink speed is an "on-off" per second, repeat. If it's faster, then it things a bulb is out.
Mine are all LEDs, no hyper-flash either...
This is how fast sequential signals run on the S197s
Iceman62
Bullitt 6005
NE
OP; Where did you buy the kit & who's the manufacturer (make/model/part)?
Dwain Pate
Hi 08MustangDude. Thank you for the info. I'm thinking of changing to leds.
08MustangDude
Resident Fuktard
Yours are not blinking any faster; from ON to OFF. The sequence may be faster,
but from ON to all three OFF, it's the same.
