Project “Slow White”
NoviBlownGT
Boosted Crew
Marion, IN
get that 60ft time down into the 1.2x you will most likely have a 7 second car.
That’s my major setback right now. I need to swap to a slipper clutch and add another 10-15# and see what itll do.
Adding a slipper clutch to a stock case/bell TR6060 is my issue.
Sactown
Sactown
Sacramento, CA
Your mustang is still a stick shift? Put a power-glide in that girl and let her eat!
Your car is still stick? Put a power-glide in that girl and let her eat!
NoviBlownGT
Boosted Crew
Marion, IN
I went auto in my blue car and it just wasn’t for me. Banging gears to 160+ is a thrill I don’t want to give up.
Once the car gets more advanced and people start bragging about 3V records I will throw a glide in it to prove what it can do.
Until then banging gears is just more fun.
Sactown
Sactown
Sacramento, CA
What are the 3V records? I have not seen a 3v that is still 281CID run quicker than my car, bigger turbo and some weight reduction I'll be in the 4's running an 1/8th, which would be deep into the 7's in the quarter.
Drive a stick is much more fun, but I picked up a full second in the quarter switching to an auto, couldn't believe it.
NoviBlownGT
Boosted Crew
Marion, IN
Aside from Mo’s 326ci build that went 7.6s there are a decent amount of quick ones now. Eric Lawrence went 8.16 at 281ci with smaller single. Kevin McDonald has been 7.8s I believe in his 3V fox.
Cracking into the 4s doesn’t normally correlate to “deep” into the 7s unless your really pouring it on up top.
Ed Pierce went 5.teens I believe in a 282 s485 build.
I think it’ll be super tough to get an S197 weight 3V sub 7.50s.
NoviBlownGT
Boosted Crew
Marion, IN
Well after a disappointing time at Mod Nats, I’m up and running again.
Fired up last night after the winter repairs.
No changes this year for the first time ever.
Sactown
Sactown
Sacramento, CA
I have a couple of changes in mind, but need to save up the $$$ first, sucks not being rich lol
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
Wait a minute, are you still running an RST clutch?
My RST clutch needs over an hour to cool after an 1/8th mile run or it would not go into 3rd gear and sometimes would not even go into gear on the return road, swapping it out to an RXT one of these weekends.
06StangGT
Syracuse, NY
Negative. As of late January, he was running an RXT1200 on a RPM level 6 6060
NoviBlownGT
Boosted Crew
Marion, IN
Yeah I sent my RST in and had it upgrade to an RXT1200. So far so good!
86GT351
Sunny South Florida
No 60 foot and no 1/8 mile. That is hauling ass on the top side. Someone is smiling down on you for sure!
tjm73
of Omicron Persei 8
Rush, NY
Got a parachute installed? wow.
Full manual reverse valvebody "automatic" is still you choosing to bang the next gear. Quicker. Faster. More consistent. Less violent on the driveline. All wins.
NoviBlownGT
Boosted Crew
Marion, IN
Thanks man. I only got a handful of passes in last year on the new setup. I should be able to get that 60ft down into the 1.4s at least. Then it should run a solid number.
NoviBlownGT
Boosted Crew
Marion, IN
I’ve ran a MVB auto in my other 3V. It’s just not for me. Is it quicker, yes. That’s just not what it’s about for me. I enjoy the thrill of banging gears down track. It’s much more exiting and adrenaline pumping for me.
Yes I have a parachute.
