Project “Slow White”
Discussion in 'Mustang Chit Chat' started by NoviBlownGT, Jan 1, 2019.
  1. Snakethat
    Snakethat forum member
    224
    21
    This is a reason to give thanks. Badass!!!!!!
  2. Sactown
    Sactown Sactown
    5,311
    58
    Can't get over that MPH, insane
  3. NoviBlownGT
    NoviBlownGT Boosted Crew
    479
    Me either! Espeically on only 24#.
  4. Sactown
    Sactown Sactown
    5,311
    58
    get that 60ft time down into the 1.2x you will most likely have a 7 second car.
  5. NoviBlownGT
    479
    That’s my major setback right now. I need to swap to a slipper clutch and add another 10-15# and see what itll do.
    Adding a slipper clutch to a stock case/bell TR6060 is my issue.
  6. stkjock
    stkjock ---- Madmin ---- Staff Member Administrator Super Moderator S197 Team Member
    37,845
    829
    :bravo:
  7. Sactown
    Sactown Sactown
    5,311
    58
    Your car is still stick? Put a power-glide in that girl and let her eat!
  8. NoviBlownGT
    479
    I went auto in my blue car and it just wasn’t for me. Banging gears to 160+ is a thrill I don’t want to give up.
    Once the car gets more advanced and people start bragging about 3V records I will throw a glide in it to prove what it can do.
    Until then banging gears is just more fun.
  9. Sactown
    Sactown Sactown
    5,311
    58
    What are the 3V records? I have not seen a 3v that is still 281CID run quicker than my car, bigger turbo and some weight reduction I'll be in the 4's running an 1/8th, which would be deep into the 7's in the quarter.
    Drive a stick is much more fun, but I picked up a full second in the quarter switching to an auto, couldn't believe it.
  10. NoviBlownGT
    479
    Aside from Mo’s 326ci build that went 7.6s there are a decent amount of quick ones now. Eric Lawrence went 8.16 at 281ci with smaller single. Kevin McDonald has been 7.8s I believe in his 3V fox.
    Cracking into the 4s doesn’t normally correlate to “deep” into the 7s unless your really pouring it on up top.
    Ed Pierce went 5.teens I believe in a 282 s485 build.
    I think it’ll be super tough to get an S197 weight 3V sub 7.50s.
