Power upgrades
Frankief28
Brooklyn
Hey wondering if anyone had tips or suggestions on my 2012 5.0 I’m trying to get some power gains but not go supercharger just yet maybe down the road so far I have the following upgrades
Long tubes X pipe Roush catback
JLT intake
Aluminum driveshaft
93 tune
Oil separator
Lowered 1.5 drop
Pan hand bar
Control arms
Was thinking of 3.73 later on prob. Not going to do cams because for the money I rather go super charger.
Anyother upgrades that are n/a? I was thinking boss 302 intake but I heard you lose a lot of TQ when the car was stock It dyno 370 to the wheels and it’s a auto thanks
Dino Dino Bambino
I have a red car
Cyprus
The only other N/A power upgrade available to you without going inside the engine is the 2018 GT intake manifold. You won't see much difference at lower rpm but there are huge HP gains above 6500rpm where the performance of the '11-'17 GT manifolds drops off. You could also add the Boss 90mm throttle body for further gains. Both are going to require a custom tune and you could raise the rev limiter to 7400rpm.
If the 2018 intake manifold doesn't look sexy enough for you, go for the Cobra Jet instead.
There is some power to be had with a tune. Specifically cam timing.
Iceman62
Bullitt 6005
NE
Adding up the co$t of everything listed...you should just go w/ supercharger & be done w/ it. :D
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
You've already addressed the easy stuff so a converter would be a good idea. A better idea would be to supercharge it and then get the converter after.
Dino Dino Bambino
I have a red car
Cyprus
I suggest you do the 3.73 gears first. They'll really make a difference over the stock 3.15. You'll need to use your handheld tuner to alter the axle gear ratio stored in the ECU so that the speedo and the tranny shift points remain correct.
After the gears are done, you can then upgrade the converter. With your mods, the torque curve will rise quite steeply from lower rpm and begin to level off a bit around 3500rpm, so that's the rpm I suggest you choose as the stall point.
The gears will do nothing while a converter will make a significant difference.
Your kidding me right? Gears act as a torque multiplier. In simple terms it multiplies your power output to the wheels.
I would actually wait on a converter until you get close to the power you are going for. Stall speed will change with your engines power output. Where your car makes peak torque will determine where you want your converter stall speed at. If you put one in now and then make changes to the power output you might have to pull it and get it restalled. That's kinda a pain, don't ask me how I know this.
JEWC_Motorsports
S197 Junkie
Is this goal for drag racing or playing on the street? 3.73's are great on the street and suck on the track. On 3.73's and drag radials id pull 1.9 60ft on the track. Spinning isnt winning. Who is the tune by? The converter with 3.31's was the best 2 mods i've done. If you plan on doing a supercharger down the road hold off on the converter. They are different between n/a and boosted applications.
tjm73
of Omicron Persei 8
Rush, NY
Tune, suspension stuff and keep saving for the boost.
Snakethat
Brownsburg,IN
Two greatest mods i have done. Supercharging and torque convertor. Add the torque convertor after supercharging made the car wake up like nothing else. You need to just save the money for these two upgrades and as was mentioned already start on suspension.
OX1
Jackson, NJ
^^^^ This
X3. All I did was powerwise was the Rousch Phs 3 blower, not even using open air cleaner and VMP tune.
Hunted around a while and found blower $1000 cheaper than anyone at the time, $5200.
Think you could spend double on NA mods, and not get to what only a TVS gets you.
Otherwise, sounds/drives stock, except for severe low end torque issue :)
See five Oh Brian's thread on his 2014 auto. Only mods were DR's, tune, 5k stall converter (with a 2:1 tq ratio). Stupid fast. Kelly at BMR, replaced the 3.15 with a 2.73 on his auto.
https://www.s197forum.com/threads/14-gt-automatic-drag-racing-results-from-a-few-simple-mods.113854/
Very commendable and a cool journey and all, but it took 4 years to go 2 tenths slower than my second pass ever in the car. That and if we are really comparing $, he had offroad H, big/littles, and $500 coils (that didn't work out, but still money spent).
The other issue for me is being in a Lib state, wasn't sure if NJ was ever going to go back to more than just OBD connection for emissions. I really wanted twins, but if they went back to visual, or worse to private garages, I'd have been screwed with twins, or even just long tubes (not swapping them out every 2 years). At least Roush blower has an OE #, so it looks all legit if you used their closed air cleaner.
Laga
Chicago
What converter did you go with?
