02 gt grinding sound
07gts197
Naples, Fl
I know there is another section for all s197’s but I cant find it on tapatalk. Anyway my 02 gt has been sitting for a few months because work has been so busy. I just got it back up and running but theres one issue. Theres a grinding sound like a circular saw cutting a 2x4 when in 3rd and 5th only. Easing off the gas seems to pretty much eliminate it. It sounds like its coming from the flywheel/clutch area. Any ideas what it might be?
By the way it has a tr3650.
SPeace-ATL
That sounds a lot like the sound the rear cluster bearing makes when it is getting loosened up.
The dynamics of pressure on that bearing are different for different gears and with/without load.
I don't know what sound the front cluster bearing makes when this happens, but on a TR3650 the nylon fork pad inserts tend to crumble and the plastic debris always seems to get trapped in the front cluster bearing cage. I can't see why that would affect only a couple of gears, but again, the dynamics of the cluster shaft do change with the different gears - particularly if the bearings have loosened up.
My suggestion is to replace the bearings and shim it up properly.
May as well replace the synchro rings too while it is apart.
Stan
07gts197
Naples, Fl
Before I get too deep Im going to dump the fluid but if that doesnt work I might just upgrade. It wasnt making a peep until after it sat.
07gts197
Naples, Fl
Yesterday I dumped the old fluid and refilled it with dex/merc, no difference. I though if it was internal it would be affected by new fluid but no it seems there is no change at all. Id hate to buy a new trans and find out this one isnt broken. Any other suggestions? Its odd how its only affected by certain conditions. Like if Im in 5th and press the clutch in it wont do it, like only when there is no load. It just seems odd to me as 5th gear and the input shaft is still spinning.
SPeace-ATL
I still think it is the rear cluster shaft bearing. Listening to the video, it seemed fine in all the other gears. I've heard that sound once before and that was the issue. The noise would come and go. It mostly did it in fifth gear and it had to be traveling "at speed" before it would do it. That one bearing is a "slip-fit" on the cluster shaft and is not pressed on. If those rollers aren't turning freely the center part of the bearing will spin (metal to metal) on the cluster shaft and make strange noises.
Stan
07gts197
Naples, Fl
Stan
Not that I don’t believe you I’m just not sure. I’m assuming you’re referring to the output shaft bearing, and from what I’ve read is that it would keep making noise as long as the driveshaft is turning. It doesn’t make sense that it only happens in 5th.
SPeace-ATL
That is true about the output shaft bearing and that one rarely goes bad because it is so large and heavy-duty, BUT, NO, I am talking about the rear CLUSTER SHAFT bearing. Now, if that cluster bearing went completely bad it would make noise anytime the input shaft is turning, (input shaft gear turns the cluster shaft all the time) BUT for the TR3650 there is a curve-ball setup for that one bearing in that is does not press onto the cluster shaft (AKA Counter Shaft). It is a slip fit and under some conditions, especially when the bearing is stiff, or the shimming is loose, it will spin on the shaft rather than roll on the needle bearing rollers. This is pretty rare.
I am not making this up. I am into these transmissions on my workbench almost every day. I built a transmission that immediately had that same noise in fifth gear on the highway. There were no other complaints. I found the rear cluster bearing was spinning on the cluster shaft. I replaced that one bearing and re-shimmed the bearing and it was fine.
The dynamics of the cluster shaft change when fifth gear is pulling because the fifth gear is beyond the rear cluster bearing. All the other gears that use the cluster shaft are between the front bearing and the rear bearing. Lateral stress on the fifth gear makes the shaft tend to pivot on that rear bearing and if the shimming is loose then it can move. The T-45, TKO, and the T-56 family of transmissions have a third bearing on the rear tip of cluster shaft that can prevent the shaft from wallowing in the bore in fifth gear, but not the T-5 nor the TR3650.
Stan
07gts197
Naples, Fl
I wasn’t insinuating that you didn’t know what you were talking about, I’m just not convinced but if you think thats what it is you’d know better than I would. Do you think this bearing can go bad after sitting for a month or so?
SPeace-ATL
I wasn’t insinuating that you didn’t know what you were talking about, I’m just not convinced but if you think that's what it is you’d know better than I would. Do you think this bearing can go bad after sitting for a month or so?
Almost anything can happen... When I think "I've seen it all" something new surfaces! If there is some debris in the bearing so that it doesn't want to spin freely it would be easier to spin on the shaft than to "roll".
I'm not offended. I just know that there are lots of people on forums that don't have the experience and are tossing out advice that is flawed. I needed you to know I have lots of experience with these transmissions. It isn't proper to actually plug my business on a forum since I am not a sponsor here but I want to share my knowledge and help people with transmission issues as best I can.
07gts197
Naples, Fl
Well I appreciate the help.
So I took it out for a short spin to see if anything else popped up and I got a few interesting tidbits. The noise is also happening to a degree in 2nd and 3rd but only during engine braking in 4th. Also its affected by suspension (ie. bumps in the road) and I noticed my clutch engages really close to the floor. While in reverse if I don’t give it any gas with my clutch maybe an inch off the floor it’ll stall. I’m thinking there is more than one issue going on now.
SPeace-ATL
Hmm, something seems to be going on in the clutch area if the pedal engages so close to the floor. It could be a stretched cable, or the quadrant adjustor could have slipped. The adjustment for the cable is to pull up on the pedal. You did say this is a 2002? A bad throwout bearing can make similar sounds, but that only varies with pedal pressure and RPM. The TOB won't care which gear you are in. I know that noises deep in the transmission often sound like they are in the bell housing and sometimes differential noises sound like they are in the transmission!
I tend to agree that these two issues are probably not directly related.
The rear cluster bearing CAN make noises in any gear. Even in neutral with the clutch pedal up, but from experience, I've seen it be really noisy in fifth gear at highway speeds. Again, I attribute that to the dynamics of the fifth gear being to the rear of that bearing and putting a different stress on the bearing.
Stan
07gts197
Naples, Fl
Just to piggyback off of this, I got under it the other day and took a video or the amound of play the drive shaft has. The front u joint seems fine but it has a bit of rotational play which I feel is excessive but I’m no expert. Also the drive shaft can slide in anf out of the transmission a little, is that normal? I can’t find any info on it. And I also noticed that the sound does only come on in certain gears but is speed related not rpm related so I figure it has to be the tailshaft area. If you listen close in the video in my other post you can hear how the noise is like a continuation, for the lack of a better term, of the noise when in 3rd and 5th.
This one is of the drive shaft play.
SPeace-ATL
Put it in Fourth gear and the only play in the transmission will be the yoke and the clutch splines. The input shaft will be coupled to the output shaft directly by the 3-4 Synchro hub assembly. (There will be very little play in a synchro hub itself.)
In any other gear, say first, the play is cumulative. Yoke, to First gear (via the synchro hub), to Cluster, Cluster to input shaft, input shaft to clutch. A little in each of those places adds up. There will be even more play in reverse!
It seems pretty normal to me.
But a noise that is SPEED related only and not rpm related would generally indicate output shaft and back. This includes noises (whines) are likely radiating from the differential or u-joints... Possibly the rear main bearing in the transmission, but those hold up really well. The front mainshaft bearing sounds should vary with RPM...
Stan
07gts197
Naples, Fl
Listen to the first video and tell me what you think. Its speed related not rpm related but yeah its weird because it seems to be coming from the trans itself but all the things it could be are in good shape. What do you think about the drive shaft being able to slide in and out of the transmission?
SPeace-ATL
When I listen to the sounds in the audio I go back to that rear cluster bearing because that is the sound I have heard it make. When describing noises people use different terms and that is why I seem to be going all over the place.
This thread calls it a "Grinding" noise. That wording makes me think of gears grinding during a shift which this is not.
I can barely hear something in third. Fourth is naturally quiet due to the construct of the transmission.
Differential noises and u-joint noises are speed related and don't care at all what gear you are in.
The fifth gear will always be spinning as long as the output shaft is turning. The rpm just increases with the speed.
The yoke is designed to go in and out, but that only happens as the rear suspension goes up and down. If it is on a lift you should not be able to slide the yoke in and out because the drive shaft should hold it in place. If the yoke goes in and out by hand then look at the u-joints and on back to the differential. There should be no front to back play to the drive shaft, just rotational play. Why would the drive shaft have enough slack to be free enough to let the yoke go in and out? You should be able to spot that. See if the pinion gear on the differential will go in and out...
Stan
07gts197
Naples, Fl
The biggest issue is the car doesn’t have plates so I’m doing all the work in my driveway on ramps and this car is low lol. Next time I’ll back it up ramps to play around with the rear end.
You’re right about the noise, maybe scraping or whining would be more apprpriate.
