axle back
Ghost1
Purchased 3 axle backs from american muscle msrp & s something none fit any suggestion!
post in the correct section.... moved
how about you also be more descriptive of the fitment issue...
thailand
MontCo, PA
My MBRP fit pretty well. I did have to slightly bend the hanger a bit, but they fit better than the Pypes I had before.
But, stkjock is right...what "didn't fit"? The hangers, slip fit? Both are pretty easy fixes, and most need a little persuasion...
06 T-RED S/C GT
Carnegie, PA
Are you referring to the hanger rods that are welded/attached to the axle backs or hanger brackets which are bolted to the chassis? I'm not quite sure which hangers to which your referring :shrug:
RED09GT
Equal Opportunity Offender
Kelowna, B.C. Canada
If 3 of them have not fit, it must be something that has been fucked with as far as the car goes.
Did a previous owner put on a jobber over the axle pipe? Has the car been hit in the rear?
Forty61
Dallas, TX
This needs to be answered first, assuming this isn’t a troll post. One not fitting could be a defect, three points to something else.
Photos of the underside of the car would probably help too, showing the hangers and the over-axle pipes.
Iceman62
Bullitt 6005
NE
Either (1) you're not ordering the correct part f/ your vehicle, or (2) something's amiss w/ your existing car/exhaust. Which is it?
Hangars on the frame installed wrong? Looks to be 90* off to me.
07gts197
Naples, Fl
I second that, and maybe try loosening the clamps on the over axle pipes at the mid pipe to get more adjustability.
07gts197
Naples, Fl
But aftermarket mufflers aren’t made to Ford specs so fitment is all over the place.
thailand
MontCo, PA
Are the tips clamped on? If so, I don't think the muffler is correctly oriented to match the hangers. I think that you may have to try and install the hangers and muffler, and leave the clamp to the H-pipe loose. You will probably be able to line it up, or see where you have to do some adjusting. I'd take the muffler tips off for now, as they may be impeding your install.
06 T-RED S/C GT
Carnegie, PA
His mufflers are on the proper sides. The orientation of the tips are properly angled where there supposed to be. It's his hangers on the frame that are on the wrong side. Switch the hangers and the mufflers should line up correctly.
