Shop somewhere else?Purchased 3 axle backs from american muscle msrp & s something none fit any suggestion!
Are you referring to the hanger rods that are welded/attached to the axle backs or hanger brackets which are bolted to the chassis? I'm not quite sure which hangers to which your referringMy MBRP fit pretty well. I did have to slightly bend the hanger a bit, but they fit better than the Pypes I had before.
But, stkjock is right...what "didn't fit"? The hangers, slip fit? Both are pretty easy fixes, and most need a little persuasion...
If 3 of them have not fit, it must be something that has been fucked with as far as the car goes.
Did a previous owner put on a jobber over the axle pipe? Has the car been hit in the rear?
You might want to zoom in on the pictures.His mufflers are on the proper sides. The orientation of the tips are properly angled where there supposed to be. It's his hangers on the frame that are on the wrong side. Switch the hangers and the mufflers should line up correctly.
