scramblr
I run the Red Top. Yellow Top died after 13 years.
Optima Red Top Battery, Group Size 34/78, 800 CCA
Thanks What year is your Stang/V8 ?This is what i have in mine since since Sept 2015 and is just fine
Optima AGM Battery D35 Group Size 35 620 CCA
https://www.autozone.com/miscellane...-battery-d35-group-size-35-620-cca/605893_0_0
Thanks this is very helpfulI run the Red Top. Yellow Top died after 13 years.
2007 Mustang GT (4.6L 3V)Thanks What year is your Stang/V8 ?
Optima moved to China. Quality went to CRAP... I had some of the old ones last 12 years. Now they are a CRAPSHOOT on getting 3 years...
Mexico actually, and it’s still the same machines used as well as lead.
I don’t have any issues with them. But got to be used for the right reason. I wouldn’t spend the extra for one in a daily. There just me tho.So are they still great batteries or not ?
"Right reason" The whole point of a batteries life is to provide energy to start the car. It would seem to me the ONLY reason to buy one is if you have a car you want to make sure starts EVERYTIME which I do. Thanks for your reply
In some cases it goes beyond that. After a race I like to run the electric water pump, radiator fan and the HE fans to cool the motor down. Do that with a regular battery a few times and chances are the car won't start for the next run.![]()
Yellow tops are also deep cycleable.
Does rinning the fans matter with the engine off? No water is.circulating unless you have electric water pump.
