I run the Red Top. Yellow Top died after 13 years.
Optima Red Top Battery, Group Size 34/78, 800 CCA
Thanks What year is your Stang/V8 ?This is what i have in mine since since Sept 2015 and is just fine
Optima AGM Battery D35 Group Size 35 620 CCA
https://www.autozone.com/miscellane...-battery-d35-group-size-35-620-cca/605893_0_0
Thanks this is very helpfulI run the Red Top. Yellow Top died after 13 years.
2007 Mustang GT (4.6L 3V)Thanks What year is your Stang/V8 ?
Optima moved to China. Quality went to CRAP... I had some of the old ones last 12 years. Now they are a CRAPSHOOT on getting 3 years...
Mexico actually, and it’s still the same machines used as well as lead.
I don’t have any issues with them. But got to be used for the right reason. I wouldn’t spend the extra for one in a daily. There just me tho.So are they still great batteries or not ?
"Right reason" The whole point of a batteries life is to provide energy to start the car. It would seem to me the ONLY reason to buy one is if you have a car you want to make sure starts EVERYTIME which I do. Thanks for your reply
In some cases it goes beyond that. After a race I like to run the electric water pump, radiator fan and the HE fans to cool the motor down. Do that with a regular battery a few times and chances are the car won't start for the next run.
Yellow tops are also deep cycleable.
Does rinning the fans matter with the engine off? No water is.circulating unless you have electric water pump.
