Car stumbling at 3k - 4k RPM and thrown into safe mode
theRedStorm
Car runs perfectly fine in the lower RPM range.
Threw a P2106 and p061b code. So I got new tunes + a new 60mm throttlebody. Still does the same thing. I'm thinking misfiring/coil packs.
Car has 87k miles. Spark plugs I'm 99% are originals lol. What's the life span of coil packs?
Anyone else have any ideas?
Here's a video
Dino Dino Bambino
I have a red car
Cyprus
Your codes are related to the throttle actuator. Since you've replaced the throttle body, you'll need to verify that the TPS voltage is within spec. Also check the wiring harness to the throttle actuator for any breaks or shorts.
theRedStorm
Happen to have a video/pdf on voltages?
