Changing Clutch Matter Cylinder
BlueChappy
Hey everyone. I’m trying to change my clutch master cylinder on my 2005 mustang GT. I pulled the low pressure hose from the brake fluid reservoir. Then I pulled the hairpin (see picture) from the clutch master cylinder that holds the high pressure hose in place. I know the high-pressure hose should pull out easily, but it’s seemingly stuck. Any ideas what to do to pull it out? I tried pushing it in, twisting it, pulling it, and nothing seems to work. Please, please, please, if anyone can help, I would appreciate it.pin.jpeg HP Hose.jpeg
Mustangk
Did u get it ? Pull harder ? Use a pair of extendeded length extended reach long nose pliers to pry it out, carefully, don't crush anything. That's how I did it I think. How much do you weight ? Because I'm a skinny tall and weak human who was able to get it out with a slight struggle. So it is kinda difficult perhaps if ur not athletic if that's the right 2word to use
BlueChappy
I gave up for the day… will work on it on Monday again. Frustration settled in. As far as me… I’m very athletic… but I understand what you’re saying… not sure why it’s not coming out.
JeremyH
3V Fuel Guru
Virginia Beach
Maybe try pushing the clutch in to get the fluid pressure to pop it out might be a little messy though so have a rag ready.
Rick Simons
Just keep yanking on it, but make sure you pull as straight as possible. Mine was stubborn too, I think it was the o-ring that was stuck..
ghunt81
New parts on old junk!
Clarksburg, WV
Mine was like that too. I had to get a small screwdriver behind the metal lip and work it out a little, once it gets started it comes out a lot easier.
