whitmanink
as some of you may or may not know,,, my engine decided to destroy itself, so now i need to get her out,,
so this weekend i plan on pulling the block only ( my garage isnt tall enough for both (engine/trans),,the garage roof A/frames get in way after about 8 ft)
so is it easier to pull the block from the car,, or lift the body up and roll the engine trans out as one?
anyone with experience on one or both?
if removing just the engine from block, where should i connect the engine leveler so i have the best shot on the block without damage >? (my heads are off the engine)
also, any hints or tips while doing it this way to ease the pain it is lol?
and, if lifting the body up and rolling out the engine \trans as one, what needs to be disconnected other than the steering wheel and clutch line, driveshaft , ?
again,, any tips or tricks if doing it this way>?
i think i got a lead on a good motor ( a great member on this forum)
so id like to start pulling this motor and see if i can save the block or if its trash..
thanx guys
thanx guys
