Fuel line seeping
Wolf302
Has anyone had issues with the fuel line connector to the fuel rail seeping? Any success repairing it?
I cleaned mine to get a better idea of where exactly it’s coming from but it seems to be seeping from the connector itself and as far as I know the entire line is a discontinued part. Thought I might be able to swap o-rings but they’re pretty recessed in the fitting.
M-Stv54
Phoenix,AZ
I need the same line and ford discontinued the part . did you ever figure out how to stop the leaking ?
Dino Dino Bambino
I have a red car
Cyprus
It sounds like you'll need to improvise a solution. I suggest you cut away the section with the plastic connector, fill the gap with a short section of metal pipe (as a female connection) on the left where there's rubber pipe, and add a short section of rubber pipe (rated for fuel systems) to bridge the metal pipes (as a male connection), securing them all together with hose clamps (double clamp each joint for extra safety).
86GT351
Sunny South Florida
Not sure where you are located. See if there is a Hydraulic hose repair facility near you. They might be able to replace the leaking end for you.
pass1over
I like it LOW
Trenton, FL
had this happen to me. I leaned a little bit on that fitting, didn't realize it was there and broke the line. You can buy a new quick fitting for the fuel line at an auto parts store. Just cut the old one off and insert the new one.
GriffX
Rural Germany
Or, if it is only an O-ring, buy a new connector and transfer the o-rings. This connector can be disassembled. (At least this types I have in mind)
Kev555
Ireland
There's plenty of aftermarket options out there for fuel line retrofits, you may get lucky with a female connector like in this kit I posted as an example or do as Dino stated.
