TR3650 Impossible to find shifter hardware
Bodvar
For the bracket and all the bolts I have? $20 + shipping. I'll throw in the whole shifter w/ the urethane bushings if you want
I have a shifter and bought new bushings already so I just need the bracket and bolts. I can send cash app or venmo
cavero
NoVA
Apparently I can't attach files in personal messages, so I'm posting them here. I've got the bracket, the nut that holds the shift arm to the block on the rear of the transmission (The stud is actually part of the shifter arm), and I found 2 bolts in my parts bin, one looks suspisciously like the one labelled HB1 in the parts diagram (on the left right ), but I'll throw both in the package.
On the shifter arm, there's also plastic bushings and O-rings. Do you need those too?
cavero
NoVA
The nuts that hold the bracket onto the underside of the transmission tunnel are
Part#: W520101S440
Usages: M6, Nut, 09/07/2004 - 03/22/2010, Mustang (2005/), TR3650 5-Speed Manual Transmission
Since that's an M6 nut, you can probably just find some at a hardware store or Autozone if you don't want to shovel out $11 from Ford (wonder if Autozones might have better corrosion protection).
Found an old thread here from a few years ago where a guy had the part number for that bolt, and following the link to fordpartsgiant in that thread, it does look actually look like the one on the right in my picture. :thumb2:
Black08Bullitt
New Jersey
Hey all. I'm swapping my auto 05 over to a manual. Everything is going fine so far with the limited time I have to work on it. I'm almost done with it, but I'm missing some parts for the shifter assembly for the TR3650. This being the bracket that holds the shifter to the body as well as the bolts. Does anyone know the bolt sizes that I need or do you have alternatives to the bracket that works? Even better, who has parts that I can buy from you?
I had this shift linkage bolt/pin snap twice. The ford part number is 4R3Z7C211AA. You can buy it directly from ford online.
