Timing Set Costs What???
Wow, $600 for a timing set??? I don't remember how much I paid when I did it last time but I know it wasn't anything as eye opening. Just thought I would share my sticker shock. I think I'm going to pull the cover first and see if I can get away with just ordering a couple of components as opposed to the whole set.
JC SSP
FL
Yeah between chain, tensioners, phasers, followers and oil pump, etc that’s what I was expecting.
cavero
NoVA
The ones I was seeing online (Cloyes) were about $600 w/ the solenoids (partsgeek),
Cloyes Timing Chain Kit and Water Pump
Part Number:
18979-02202865
Notes: Engine Timing Chain Kit with Water Pump -- with Water Pump; with VVT Sprockets and VVT Solenoids.
  • Kit Contains: Timing Chain (2), Timing Chain Tensioner (2), Timing Chain Guide (2), Timing Chain Tensioner Guide (2), Timing Crankshaft Sprocket, Variable Valve Timing (VVT) Sprocket (2), Variable Valve Timing (VVT) Solenoid (2), Water Pump
JC SSP
FL
Cloyes used to make good double roller timing chains but I always thought Ford OEM was the best for the 4.6L.
Curious to hear what others have to say…
86GT351
Sunny South Florida
Contact Lethal Performance. They are a Ford Racing Dealer and might be able to get you a better price. Replace everything you can. Don't just do piece work. I can assure you that you will have to do the job again in the near future.
JC SSP
FL
Yeah I agree... I am at 120K and every so often I hear a small tick on initial startup, so I know I have to do this in the near future.
I will definitely change everything (i.e. oil pump, followers, etc.) with OEM or performance upgrade, just trying to figure out which are best (oil pump, tensioners, etc.). I wish someone would post a detailed list of parts needed... FYI I will be sticking with stock cams & valve springs.
Dino Dino Bambino
I have a red car
Cyprus
They sell the same camshaft drive kit for $644. That's $85 more than Summit Racing.
Here ya go:
Ford Performance Camshaft Drive Kit: M-6004-463V
Ford Performance Rocker Arm Lash Adjuster Kit: M-6529-3V
Felpro Timing Chain Tensioner Gasket Set: ES73226
OEM '13-'14 Shelby GT500 high pressure oil pump (Ford part no. DR3Z6600A)
OEM 3V oil pump pickup tube (Ford part no. 4R3Z6622AA)
If you're interested in any other ideas on how to bulletproof your 3V, go to https://www.angelfire.com/my/fan/Mustang2006GT/Engine.html
JC SSP
FL
Dino I owe you a cold one! THANK YOU.
Should be a sticky for future use.
86GT351
Sunny South Florida
Here ya go:
They also have coupons available for forum members. In other words, call they might have a better price available.
JC SSP
FL
Yeah I am calculating $1,000... will wait for July 4 sales
Well stopped by CJ Pony Parts and picked me up a new timing set and valve cover gaskets. Also picked up an extra FelPro main seal for the front. My las one leaked a little so I bought a different one hoping I'll have better luck.
I will probably repaint my front cover while it's off and get a new set of pulleys so I can get her back to the way she was.
JC SSP
FL
What tensioner and idlers are those? Very cool!
Pulleys are from Metco I believe. I bought them as a set for the 3v and then had them swap an 80mm for a 90mm that my whipple needs. The tensioner is the Thumpracing billet arm. Its an HD unit for those with blowers.
My last call to Metco had them unavailable. If they aren't in stock I might just take them down to a machine shop and have them press out and replace the bearings.
